June 20, 2021, 23:08 |
wall Shear Stress in Solids4Foam
alberto
Rep Power: 10 |
I am working with FSI in arteries, I did my simulation using solids4Foam, and now I'm searching how to obtain the wall shear stress in the fluid wall. I've tried with: solids4Foam -postProcess -func wallShearStress solids4Foam -postProcess -func wallShearStress -region fluid Also the next function in controldict wallShearStress1 { type wallShearStress; libs ("libfieldFunctionObjects.so"); patches ("wall"); region fluid; } and I tried to copy the fluid files like fluid case in OF v8 and use the following command with out sucess pimpleFoam -postProcess -func wallShearStress If someone knows how to do it and shared it, I would appreciate it. Regards. |
Natural convection in a closed domain STILL NEEDING help! | Yr0gErG | FLUENT | 4 | December 2, 2019 01:04 |
Wall Shear Stress Sampling Probes | Mahe88 | OpenFOAM Post-Processing | 0 | December 14, 2016 11:09 |
Wall Shear Stress prediction varies with fix y+ | Jeeloong | FLUENT | 0 | November 24, 2016 18:17 |
Exporting wall shear stress in relative frame of reference | gotang | FLUENT | 0 | September 15, 2014 11:35 |
Re: About wall shear stress | Mike | FLUENT | 9 | November 17, 2003 15:41 |
