Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Bouncing ball
Like Tree3Likes
  • 1 Post By bigphil
  • 1 Post By bigphil
  • 1 Post By bigphil
Old   March 16, 2020, 15:57
Default Bouncing ball
Bruno Ramoa
brunomramoa is on a distinguished road
Hello to all,
I am trying to create a bouncing ball simulation with solids4foam. Something similar to this https://www.youtube.com/watch?v=WwZj8JXrLIo.
I started to assemble this case from the impact bar tutorial but now I am having some trouble with the initialization of the case.
I used the setFields to set the ball velocity to a very small value (1e-6) but it will not gain velocity due to the acceleration of gravity.
Does anyone have experience with this?
link for the case: https://drive.google.com/file/d/1Agw...ew?usp=sharing
Additionally, is it possible to get the kinetic and internal energy from solids4Foam?
brunomramoa is offline   Reply With Quote
Old   March 19, 2020, 06:10
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Originally Posted by brunomramoa View Post
Hello to all,
When there is rigid body motion, I have found that using equation relaxation is a bad idea as it essentially eradicates rigid motion. Try the following relaxation settings in system/fvSolution:
relaxationFactors
    // Under-relaxatr ing the D equation by 0.99-0.9999 can improve convergence in
    // some cases, in particular when there are solidContact boundaries
    equations
        //DD           0.9999;
    // Under-relaxating the D field by 0.1-0.9 can improve convergence in some
    // cases
    fields
        DD              0.7;
Also for testing you might find it easier to start with a linear geometry solid model (e.g. linearGeometry or linearGeometryTotalDisplacement): they will have better convergence and allow you to learn the "good" settings for your case before changing to non-linear geometry.
Also for rigid motion, the solver struggles to define a reasonable normalisation factor for calculating the residuals so sometimes a time-step will go to the max correctors but if you look at the solution for different correctors it is not changing (or changing by a very small amount).
Finally, I am not sure how important the solution tolerance is in these cases but it is something to be aware of.
EDIT: Finally finally, you might need to use a finer plate mesh near the contact region as the contact quick-check algorithm can miss contact when the master and slave faces are very different in size; also a smaller time-step may help.
Philip
Daniel_Khazaei likes this.
Last edited by bigphil; March 19, 2020 at 06:11. Reason: Added "finally finally" point
bigphil is offline   Reply With Quote
Old   March 25, 2020, 15:49
Bruno Ramoa
relaxationFactors
    equations
        //DD           0.9999;
    // cases
    fields
        DD              0.7;
Philip
What about the latter part? Is there any function to keep track of the kinetic and potential energy in the system?
Best Regards!
Old   March 26, 2020, 05:11
bigphil's Avatar
Philip Cardiff
I have just pushed a commit (55bd6bb2) to the development branch which adds a new functionObject called solidKineticEnergy and the tutorial tutorials/solids/linearElasticity/plateHole/bouncingPlateHole.
You can see from the code that it is relatively straight-forward to do. I aim to add some other energy function objects when I have time (but you might want to try it yourself).
Philip
Old   March 30, 2020, 07:10
bigphil's Avatar
Philip Cardiff
I pushed the solidPotentialEnergy function object to the development branch (20e0f235), to be merged with the master in due course.
This potential energy is defined a rho*g*h as opposed to internal strain energy (stress && strain), though I will aim to add that too when I have time.
Philip
Old   November 11, 2022, 06:36
Default Brian S. Featherstone
Hylandjo is on a distinguished road
I'm moreover looking for a reply, because i am new here.
Hylandjo is offline   Reply With Quote
Old   January 6, 2023, 05:13
I also like to gain experience in this
BallSportsGames
impact sim
Unsteady Simulation Problem; Flow Around a Cricket Ball. Brock17 Main CFD Forum 5 February 12, 2017 11:58
Problems moving a ball - mesh crashes lbergmann CFX 24 February 16, 2016 09:01
UDF for oscilliating ball in a ball check valve A.Jalal Fluent UDF and Scheme Programming 0 September 15, 2015 17:42
Floating ball on free surface validations Bak_Flow FLUENT 0 November 10, 2008 17:30
Floating ball on free surface validations Bak_Flow Main CFD Forum 0 November 10, 2008 16:57
