Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
title : Question regarding multi-material simulation
Like Tree1Likes
  • 1 Post By brunomramoa
Old   January 16, 2020, 08:08
Default title : Question regarding multi-material simulation
Bruno Ramoa
brunomramoa is on a distinguished road
Hello to all solid4Foamers,
Currently, I am doing a simulation of a bimaterial specimen deforming on a plate. The specimen is composed of a very soft material with a very hard insert [more information regarding the mechanical properties bellow].
The case is defined below:
The definition of the materials was performed via topoSet [OpenFoam v1906] using the stls of the geometry.
"To create movement" I am setting a patch on the top of the specimen with a fixedDisplacement time series to move the foot 5mm along the negative y-direction.
The mechanical properties are defined with a neoHookeanElastic behaviour and a nonLinearGeometryUpdatedLagrangian solidModel. When I set the material properties of the specimen and insert to be the same, I get a complete simulation. As soon as I set them to have their respective properties, the simulation stops shortly after starting. They have a ~3 order of magnitude difference in their modulus.
I will post the dictionaries bellow.
My question is:
How can I handle this type of simulation with multi-material? Do I need to set an intermediate layer to reduce the gradient of the mechanical properties? Does solids4Foam have anything implemented in this regard?
Does anyone have any experience with multi-material simulations?
pedroavr92 likes this.
brunomramoa is offline   Reply With Quote
Old   January 29, 2020, 06:40
Pedro
pedroavr92 is on a distinguished road
Hello Ramoa,
That is an interesting question, indeed...
I am also trying to simulate some multi-Material cases and I am having problems when I set up two materials with a huge difference in elastic modulus (steel and rubber).
It would be great if someone could give some insight into this issue...
best of luck =)
pedroavr92 is offline   Reply With Quote
Old   October 21, 2021, 04:20
Francisco T
frantov is on a distinguished road
Originally Posted by pedroavr92 View Post
Hello Ramoa,
best of luck =)
Hi there
There are a few multimaterial tutorials which I have been studying and seem to work fine. Look at the solid folder on this link:
https://github.com/wyldckat/FluidStructureInteraction
Regards
Francisco
frantov is offline   Reply With Quote
Simulation multiphase airlift reactor with Eulerian multiphase model question???? dilok.kumyoo FLUENT 0 January 28, 2015 03:15
Simulation of granular material Philippe Main CFD Forum 1 February 13, 2013 09:10
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Need LES simulation knowledge / reference material Sam CFX 7 January 25, 2008 17:30
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
