October 22, 2019, 05:13 |
[solids4Foam] What is relRes in solid solution?
Ali Shayegh
Rep Power: 11 |
Hello there,
I'm currently on an FSI simulation. Can anyone explain what is relRes in the image? Where do we specify this? solids4Foam tutorial tells it has to be specified in solidProperties. A typical solidProperies is shown here, but there is no entry for relRes. Code:
unsNonLinearGeometryUpdatedLagrangianCoeffs { nCorrectors 100000; // Solution tolerance for displacement solutionTolerance 2e-06; // Alternative solution tolerance for displacement alternativeTolerance 9e-06; // Material law solution tolerance materialTolerance 1e-05; // Write frequency for the residuals infoFrequency 100; // Stabilise hydrostatic pressure field stabilisePressure yes; } Last edited by amuzeshi; October 22, 2019 at 10:54. |
December 18, 2019, 15:00 |
#2 | ||
Hojatollah Gholami
Rep Power: 7 |
It seen this report comes from solidModelTemplates.C
• relRes (relative residual: change of the primitive variable) • matRes (material residual: for nonlinear material laws) Ref:Solid mechanics and fluid-solid interaction using the solids4foam toolbox Last edited by Hgholami; December 27, 2019 at 13:29. |
Immersed Solid and FSI | Pierrm | CFX | 0 | March 26, 2018 06:36 |
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam | xpqiu | OpenFOAM Community Contributions | 8 | June 17, 2015 03:08 |
Multiple Solid Domains - Interfaces | Scott | CFX | 8 | July 31, 2008 16:20 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
