[solidMechanics] The challenges in terms of simulating rock fracture within OpenFoam? |
September 3, 2019, 09:53 |
Kaiyu Zhang
Rep Power: 7 |
Hello everyone,
I was hoping to ask for a guidance about simulating rock fracture within OpenFoam. My research is focused on developing numerical methods for dynamic rock fracture. And, I’m very interested in OpenFoam, which is based on continuum mechanics. But, I would like to investigate rock fracture within OpenFoam. I noticed OpenFoam has been developed in crack propagation, hydraulic fracture and other fracture problems. But, I’m a newcomer to OpenFoam, and still confused about whether OpenFoam could be used to investigate rock fracture, like modeling uniaxial compression test. If it does, what are the challenges in terms of simulating rock fracture within OpenFoam? Hope to receive suggestions of everyone. Best regards, Zhang |
September 3, 2019, 18:23 |
Philip Cardiff
Rep Power: 34 |
Hi Zhang,
Welcome to the forum! Would it be possible to give a link or attachment to the type of uniaxial compression test you are talking about? Philip |
September 4, 2019, 00:46 |
#3 | |
Kaiyu Zhang
Rep Power: 7 |
Thanks for your reply. Simulations of uniaxial compressive tests based on numerical manifold method (NMM) at: https://doi.org/10.1016/j.engfracmech.2018.05.010 Zhang |
September 5, 2019, 07:02 |
Philip Cardiff
Rep Power: 34 |
Hi Zhang,
I am not sure if it will work for this problem but it is possible to model cracks. You can try out the following tutorial in solids4foam: solids4foam/tutorials/solids/fracture/crackingBeams Philip |
September 5, 2019, 23:09 |
Kaiyu Zhang
Rep Power: 7 |
challenges, openfoam, rock fracture |
Linking initial data and source terms from UDF to Fluent in simulating heat pipe | say2017 | Fluent UDF and Scheme Programming | 0 | October 20, 2017 13:35 |
