Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
blockSolidTraction vs solidTraction
Like Tree1Likes
  • 1 Post By bigphil
Old   July 3, 2019, 06:14
Default blockSolidTraction vs solidTraction
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
To publicly answer a question I received via email:
Question
type blockSolidTraction;
traction uniform ( 0 0 0 );
pressure unifrm 0;
value uniform (0 0 0);
What is meaning of block? In what does this boundary condition differ from solidTraction
Answer
When using a solidModel that uses a "coupled" (block coupled) solution algorithm e.g. coupledUnsLinearGeometryLinearElastic, it cannot use the standard boundary conditions e.g. solidTraction, fixedDisplacement and instead must use "block" versions as the current block coupled implement differs significantly in its implementation. As a by the way, I am currently looking at a way that will easily allow all current standard solidModels to be solved in a block-coupled manner without having the change boundary conditions.
Philip
anaspauzi likes this.
bigphil is offline   Reply With Quote
Boundary condition: solidTraction question bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 5 September 7, 2020 07:00
