Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
Initial conditions
Like Tree2Likes
  • 2 Post By bigphil
Old   July 3, 2019, 05:49
Default Initial conditions
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
To publicly answer a question I received via email:
Question
In the tutorial solids/elastoplasticity/impactBar, there are the following fields:
  • D Displacement Vector
  • D_0 ?
  • DD ?
  • DD_0 ?
  • DD_0_0 ?
  • DD_0_0_0 ?
What are all of them?
Answer
The suffix '_0' on a file/field name indicates it is an old-time field i.e. D is the displacement field at time 0 and D_0 is the displacement at the previous time-step (if it existed) assuming the current time-step size.
To set an initial velocity (or acceleration), you should appropriately set D, D_0 and D_0_0 assuming a three time-level d2dt2 time discretisation (e.g. Euler) for and also D_0_0_0 if using a four-level d2dt2 time discretisation (e.g. backward).
You can set these fields using setFields.
If the chosen solidModel solves for DD (increment of displacement) as opposed to D (total displacement) then you would need to also set DD_0, DD_0_0 (and DD_0_0_0 for a four-level time discretisation). Note: for a constant initial velocity then all the increment fields will have the same value. Note 2: DD = D - D_0 i.e. the increment of displacement is the total displacement minus the old total displacement.
Philip
wyldckat and pedroavr92 like this.
bigphil is offline   Reply With Quote
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
chtMultiRegionSimpleFoam: maximum number of iterations excedeed. Nkl OpenFOAM Running, Solving & CFD 19 October 10, 2019 03:42
Free surface issues with interDyMFoam for hydroturbine oumnion OpenFOAM Running, Solving & CFD 0 October 6, 2017 15:05
Compressor Simulation using rhoPimpleDyMFoam Jetfire OpenFOAM Running, Solving & CFD 107 December 9, 2014 14:38
SLTS+rhoPisoFoam: what is rDeltaT??? nileshjrane OpenFOAM Running, Solving & CFD 4 February 25, 2013 05:13
