Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Community Contributions > OpenFOAM CC Toolkits for Fluid-Structure Interaction
[FSI] how develop nu() in icoFluid solver of fsiFoam
Like Tree3Likes
  • 2 Post By Daniel_Khazaei
  • 1 Post By Daniel_Khazaei
Old   March 20, 2019, 11:53
Default how develop nu() in icoFluid solver of fsiFoam
Hojatollah Gholami
Hgholami is on a distinguished road
Dear foamers
I want to add nu() as non-Newtonian fluid in icoFluid.
the problem is in here "part of icoFluid"
tmp<scalarField> icoNonFluid::faceZoneMuEff
const label zoneID,
const label patchID
) const
tmp<scalarField> tMuEff
new scalarField
mesh().faceZones()[zoneID].size(),
rho_.value()*nu_.value() //Here
return tMuEff;
void icoNonFluid::evolve()
I want to change "nu_.value" with
fluid_.nu().boundaryField()[patchID]
I add non-Newtonian fluid as fluid_(U_, phi_), then to call that I used fluid_nu.
the compiler give this error.
fluidSolvers/icoNonFluid/icoNonFluid.C: In member function ‘virtual Foam::tmp<Foam::Field<double> > Foam::fluidSolvers::icoNonFluid::faceZoneMuEff(Foa m::label, Foam::label) const’:
fluidSolvers/icoNonFluid/icoNonFluid.C:285:9: error: no matching function for call to ‘Foam::Field<double>::Field(Foam::label, Foam::tmp<Foam::Field<double> >)’
Do you know what is the problem?
Thanks
Hgholami is offline   Reply With Quote
Old   March 21, 2019, 06:01
Hojatollah Gholami
I replaced code with
const label zoneID,
const label patchID
) const
new scalarField(mesh().boundary()[patchID].size(), 0)
tMuEff() = rho_.value()*fluid_.nu();
return tMuEff;
and problem is solved
Old   March 21, 2019, 06:49
Daniel
Daniel_Khazaei will become famous soon enough
why not using pisoFluid at first place?
Daniel_Khazaei is offline   Reply With Quote
Old   March 21, 2019, 09:00
Hojatollah Gholami
Dear Khazaei
I used pisoFluid at first time, but have problem with converging. I change several time fvscheme and fvsolution, but nothing help to converge. May you know which configuration is good for pisoFluid?
Old   March 23, 2019, 10:37
Daniel
Dear Khazaei
well it is not possible to guess why the simulation diverges without knowing what kind of simulation you are trying to run.
Old   March 23, 2019, 11:43
Hojatollah Gholami
It was study of Hron Turek (benchmark FSI2) that have problem with pisoFluid. But with icoFluid is good.
Old   March 23, 2019, 14:05
Daniel
well I have already tested HronTurekFSI3 test case which should be much harder to converge without any problem using pisoFluid. Are you trying to model HronTurekFSI2 with non-Newtonian fluid?
if you are still using old fsi toolkit you need to know that the direction of the calculated viscous force is wrong and you need to correct it in pachViscousForce() function. Just multiply the calculated force by (-1).
This bug has already been patched in solids4Foam toolbox.
bigphil and Hgholami like this.
Old   March 24, 2019, 00:52
Hojatollah Gholami
The test was with newtonian fluid. In icofluid I see this code for pachViscousForce()
//- Patch viscous force (N/m2)
tmp<vectorField> icoFluid::patchViscousForce(const label patchID) const
tmp<vectorField> tvF
new vectorField(mesh().boundary()[patchID].size(), vector::zero)
tvF() = rho_.value()*nu_.value()*U().boundaryField()[patchID].snGrad();
vectorField n = mesh().boundary()[patchID].nf();
tvF() -= n*(n&tvF());
return tvF;
that neglected in pisoFluid
tmp<vectorField> pisoFluid::patchViscousForce(const label patchID) const
tvF() =
rho_.value()
& turbulence_->devReff()().boundaryField()[patchID]
// vectorField n = mesh().boundary()[patchID].nf();
// tvF() -= n*(n&tvF());
return tvF;
As your recommendation, I think you mention this
must add to pisoFluid code and the icoFluid is correct. Is it true?
Your recommend is very helpful. Thanks.
Old   March 24, 2019, 03:15
Daniel
As your recommendation, I think you mention this must add to pisoFluid code and the icoFluid is correct. Is it true?
no, just use the following code:
tmp<vectorField> pisoFluid::patchViscousForce(constlabelpatchID)const
     tvF() =
           rho_.value()
               & (-turbulence_->devReff()().boundaryField()[patchID])
     return tvF;
these lines in pisoFluid
//vectorField n = mesh().boundary()[patchID].nf();
//tvF() -= n*(n&tvF());
are commented out because we have already used face normal or nf() function during the calculation of tvF() which was not the case with icoFluid.
Hgholami likes this.
Old   March 24, 2019, 16:33
Hojatollah Gholami
Thanks for your note. I modify the code. So, do you have any proper fvscheme and fvsolution for tutorial of hron&Turek?
Old   March 25, 2019, 05:18
Daniel
I haven't used any special changes in fvScheme or fvSolution. The same case should easily work with pisoFluid...I have just modified it to work with pisoFluid.
fsifoam, non-newtonian
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 08:54
Creating New Solver: For particle-laden compressible jets sankarv OpenFOAM 0 April 4, 2010 19:06
why the solver reject it? Anyone with experience? bearcat CFX 6 April 28, 2008 15:08
Did someone develop a CIP solver tachioka OpenFOAM Running, Solving & CFD 0 October 10, 2007 11:17
Setting a B.C using UserFortran in 4.3 tokai CFX 10 July 17, 2001 17:25
