Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
problems with midPoint set sampling
Like Tree1Likes
  • 1 Post By grandgo
Old   July 4, 2011, 06:45
Default problems with midPoint set sampling
grandgo is on a distinguished road
hi foamers,
i don't know if this is a bug or not, but weird anyway.
i want to sample some points on the radius of a pipe-flow via sampleDict. the diameter of the pipe is 0.05.
by using this code in the sampleDict file:
setFormat raw;
surfaceFormat null;
interpolationScheme cell;
fields
p
U
sets
lineRadiusY4DmidPoint
        type        midPoint;
        axis        x;
        start       (0 0.2 0);
        end         (0.025 0.2 0);
surfaces();
i get this error-message
--> FOAM FATAL ERROR:
None of the neighbours of face 289377 contains point (-1.68086e-18 0.199999 6.11069e-07)
    From function sampledSet::getCell(const label, const point&)
    in file sampledSet/sampledSet/sampledSet.C at line 104.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#1  Foam::error::abort() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#2  Foam::sampledSet::getCell(int, Foam::Vector<double> const&) const in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#3  Foam::midPointSet::genSamples() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#4  Foam::midPointSet::midPointSet(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#5  Foam::sampledSet::addwordConstructorToTable<Foam::midPointSet>::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#6  Foam::sampledSet::New(Foam::word const&, Foam::polyMesh const&, Foam::meshSearch&, Foam::dictionary const&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#7  void Foam::PtrList<Foam::sampledSet>::read<Foam::sampledSet::iNew>(Foam::Istream&, Foam::sampledSet::iNew const&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#8  Foam::sampledSets::read(Foam::dictionary const&) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#9  Foam::sampledSets::sampledSets(Foam::word const&, Foam::objectRegistry const&, Foam::dictionary const&, bool) in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#10  Foam::OutputFilterFunctionObject<Foam::sampledSets>::allocateFilter() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#11  Foam::OutputFilterFunctionObject<Foam::sampledSets>::start() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libsampling.so"
#12  Foam::functionObjectList::read() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#13  Foam::Time::operator++() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#14  Foam::Time::loop() in "/sw/OpenFOAM/OpenFOAM-1.7.x/lib/linux64GccDPOpt/libOpenFOAM.so"
#15
 in "/home/stss8/OpenFOAM/stss8-1.7.x/applications/bin/linux64GccDPOpt/pisoFoamTNuLESEff"
#16  __libc_start_main in "/lib64/libc.so.6"
#17
 at /usr/src/packages/BUILD/glibc-2.11.2/csu/../sysdeps/x86_64/elf/start.S:116
But, if i change the sampleDict file a little bit to this code:
setFormat raw;
surfaceFormat null;
fields
p
U
sets
        type        midPoint;
        axis        x;
        start       (0.001 0.2 0);
        end         (0.025 0.2 0);
surfaces();
everything works fine.
the problem is: with a finer mesh it doesn't work at all, no matter what what the starting point is and i get an error message similar to that one above. in this case i have to use 'uniform' instead of 'midPoint'.
i'm wondering if this is a bug or just incorrect usage.
same problem here:
http://www.cfd-online.com/Forums/ope...ionscheme.html
best regards,
grandgo
bmikuz likes this.
grandgo is offline   Reply With Quote
Old   October 3, 2011, 19:49
nlc
nlc's Avatar
Nicolas Lussier Clément
nlc is on a distinguished road
Did you find a solution ?? A have this problem with a fine mesh and it dos not work what ever I do !!
Regards
Nicolas L.
nlc is offline   Reply With Quote
Old   December 12, 2011, 14:16
musaddeque hossein
musahossein is on a distinguished road
I think the founders of OpenFOAM have not looked at the bug part of the forum for a while and may not be doing so in the future. There are a lot of unanswered questions. So dont hold your breath for a solution. Just a suggestion. I hope I am wrong.
musahossein is offline   Reply With Quote
Old   December 12, 2011, 14:24
nlc
nlc's Avatar
I understand.
I live with the error for now as It dos not bug me enough for now to give me the will of finding the error in the C++ code. In any case I'm using now my own tool to sample and post process the data for now.
Thank you for you r interest musahossein.
Old   December 13, 2011, 04:30
Default reporting bugs
romant's Avatar
Roman Thiele
romant is on a distinguished road
Hej,
for bug reports you should use http://www.openfoam.com/mantisbt/view_all_bug_page.php which is the official bug tracker for openfoam.
~roman
romant is offline   Reply With Quote
Old   December 13, 2011, 09:58
musaddeque hossein
Originally Posted by romant View Post
Hej,
Is this also located in the users forum?
Old   December 13, 2011, 10:34
romant's Avatar
Roman Thiele
no. in order to file a bug report you have to create an account on the bugtracker website. this way the OF developers get it faster and can assign the right ppl to it.
~roman
Questions for a species transport problems (snapshots attached) aleisia FLUENT 2 October 9, 2011 05:40
OpenFOAM 1.7.1 installation problem on Fedora 14 armonica OpenFOAM Installation 16 March 31, 2011 14:16
Compiling OpenFOAM13 on AMD64 with Redhat Enterprise mbeaudoin OpenFOAM Installation 20 June 17, 2008 07:43
Problems about multi swirl tubes simulation using Jason FLUENT 4 May 9, 2008 01:33
Problem in installation of OpenFOAM sachin OpenFOAM Installation 7 January 22, 2008 02:40
