Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Bug in patchInternalField()
Like Tree1Likes
  • 1 Post By psosnows
Old   May 9, 2011, 12:57
Default Bug in patchInternalField()
Pawel Sosnowski
psosnows is on a distinguished road
Greetings,
I believe that there is a problem in implementation of the function patchInternalField().
The distribution is OpenFoam-1.7.1.
The problem was discovered while working on updateCoeffs() function of derivedFvPatchField (derived from mixedFvPatchField):
void Foam::myFvPatchScalarField::updateCoeffs()
        // <some code>
        const scalarField& thisIntField = patchInternalField();
        Info << thisIntField << endl;
        // <some more code>
In the log we should obtain values of internal field next to the studied patch (in tested case they were set to 300).
Instead, some cells contain zero value.
value nonuniform List<scalar>
2160
6.92193e-310
6.92193e-310
0
0
300
300
300
The mesh was generated using blockMesh. The geometry is shown in the figure attached. Mesh has only 2 patches- the outside one and the inside one.
New boundary condition is applied only on the inner patch.
Anomalies appear only on the faces that are next to the edges, selective, not all. Usually several first ones (like in the example above).
If the "inner" patch is divided into 6 ones, with applied new derivedBC, anomalies are not observed.
Presented usage of the function is quite basic- this drives to conclusion that there is something wrong deeper in the code. Please this bug into consideration.
I would also be very grateful for any other possible explanation of the described problem.
Best,
Pawel S
psosnows is offline   Reply With Quote
Old   July 24, 2011, 17:14
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Did this get resolved? Maybe you should report it directly to http://www.openfoam.com/bugs/
and/or
http://sourceforge.net/apps/mantisbt..._view_page.php
Cheers,
Dan
chegdan is offline   Reply With Quote
Old   September 21, 2011, 14:12
Arne Stahlmann
Arnoldinho is on a distinguished road
Pawel,
did you create a bug report for this? I have not been able to find one...
At the moment, I am facing the same problem (using OF 1.6-ext), as patch values calculated by patchInternalField() are different from internal field values in the patch near cells.
Or did you find a solution for this in the meantime?
Arne
Edit: Could someone check if the following is right or wrong:
Unw.boundaryField()[patchi] = U.boundaryField()[patchi].patchInternalField();
I'd like to compute U at the patch nearest cells and store it to a Unw volVectorField.
Arnoldinho is offline   Reply With Quote
Old   September 22, 2011, 08:46
Arne Stahlmann
Ok, having a deeper look at my results, I can so far state that the "bug" in my case only resulted from the interpolation/display scheme in ParaView:
Values from U.boundaryField()[patchi].patchInternalField() were different from U internalField values at regarded probe locations, because ParaView normally seems to use (mesh) point values instead of cell values for display. Using a CellDatatoPointData filter before setting the probe location in contrast results in identical values.
Arne
Old   October 12, 2011, 04:53
Tim Gronarz
TimG is on a distinguished road
i am facing exactly the same Problem as Pawel does. I also get four wrong values as the first entries in my Field list.
Is there a Solution to this? Is it even a Bug or did i do something wrong?
Cheers, Tim
TimG is offline   Reply With Quote
Old   October 12, 2011, 05:22
Pawel Sosnowski
Hello Tim,
this issue disappeared when I moved to OF-2.0.0. In the end I did not find out what caused it, but used a "walk around".
You can create a function and use it instead of patchInternalField
In the .H file:
virtual tmp<scalarField> ppatchInternalField() const;
In the .C file:
Foam::tmp<Foam::scalarField> Foam::NAME_OF_YOUR_BOUNDARY_CONDITION::ppatchInternalField() const
	tmp<scalarField> tField(new scalarField(size()));
	scalarField& refF=tField();
	forAll(patch().faceCells(),cellI)
		refF[cellI]=(*this).internalField()[patch().faceCells()[cellI]];
	return tField;
This one does exactly the same thing as original one, but did not cause the problem mentioned (note that OF function is a template, here you have direct specification of the type). You simply use it instead patchInternalField(). I changed the name just to know that I am using my own code, not the standard OF stuff. If you like, there should be no problem for simply overloading original function.
Hope it helps a bit.
Best,
Pawel
randolph likes this.
Serious bug in LES interface fs82 OpenFOAM Bugs 21 November 16, 2009 09:15
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 07:41
Bug in twoPhaseEulerFoam wallfunctions alberto OpenFOAM Bugs 1 February 9, 2007 15:15
Bug reports Mattijs Janssens (Mattijs) OpenFOAM 0 January 10, 2005 11:05
Forum y2k Bug Jonas Larsson Main CFD Forum 1 January 5, 2000 11:22
