decomposePar not decomposing refinement history |
July 8, 2010, 14:23 |
Kyle Mooney
Rep Power: 18 |
Hi all,
I have been getting remeshing inconsistancies between serial and parallel runs when using interDyMFoam (1.6.x and 1.7.x) and think that I have figured out the issue. I have been using interDyMFoam in serial as somewhat of a preprocessor/meshing tool to get a fine mesh around my interface. Once I had the mesh built I decomposed it and attempted to run it in parallel only to have dynamicRefineMesh re-refine the cells that were already adequate. It seems that the refinementHistory file is not being decomposed and passed into the processorX folders. Is there a way to readily decompose that file? |
July 9, 2010, 05:01 |
Mattijs Janssens
Rep Power: 26 |
Correct, the refinementHistory is not decomposed.
(the problem with it is that the history can refer to local cells only. So a valid decomposition would have to make sure that it keeps a cluster of cells originating from the same cell together. In other words base the decomposition on the coarsest level (= starting level). Not easy and then one might as well just decompose the starting mesh and preprocess in parallel) Mattijs |
July 9, 2010, 09:48 |
Kyle Mooney
Rep Power: 18 |
Thanks for the reply!
It does seem that that would be a non-trivial problem. Preprocessing in parallel seems to be working. Thanks a lot. Kyle |
[snappyHexMesh] snappyHexMesh not refining surfaces | Hydro1004 | OpenFOAM Meshing & Mesh Conversion | 3 | August 29, 2012 11:56 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
decomposePar hierarchicalCoeffs | maka | OpenFOAM Running, Solving & CFD | 1 | August 14, 2008 17:39 |
Mesh Refinement | JY | Siemens | 7 | September 19, 2002 13:37 |
