Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
alpha or alpha1 in interFoam & interDyMFoam
Like Tree1Likes
  • 1 Post By henry
Old   September 8, 2009, 07:45
Default alpha or alpha1 in interFoam & interDyMFoam
T Somerville
wavytracy is on a distinguished road
From the damBreak tutorial of version 1.5, fvSchemes looks like:
gradSchemes
default Gauss linear;
grad(U) Gauss linear;
grad(gamma) Gauss linear;
divSchemes
div(rho*phi,U) Gauss limitedLinearV 1;
div(phi,gamma) Gauss vanLeer;
div(phirb,gamma) Gauss interfaceCompression;
Now, I was under the impresssion that gamma was replaced by alpha1 in version 1.6. Yet, here is the same excerpt from v1.6 damBreak tutorial, which contains alpha and alpha1:
gradSchemes
grad(alpha1) Gauss linear;
divSchemes
div(phi,alpha) Gauss vanLeer;
div(phirb,alpha) Gauss interfaceCompression;
and it isn't even consistent - take a look at the same excerpt from interDyMFoam v1.6
gradSchemes
grad(alpha) Gauss linear;
divSchemes
div(rho*phi,U) Gauss upwind;
So what is the difference between alpha and alpha1. Am I misunderstanding something, or is this a bug?
Cheers,
Tracy.
wavytracy is offline   Reply With Quote
Old   September 9, 2009, 03:54
henry is on a distinguished road
alpha1 is the phase fraction of phase 1 in a multi-phase system, alpha in the control dictionaries refers to any phase. The reason for the "inconsistency" is to ensure that the discretisation schemes are the same for all phases.
H
nepomnyi likes this.
henry is offline   Reply With Quote
Old   September 9, 2009, 22:23
T Somerville
Thank you.
But the "inconsistency" refers to the line
in the controlDict of the interFoam tutorial,
compared to the line
in the controlDict of the interDyMFoam tutorial.
I'm assuming from your reply that they should both be grad(alpha)?
Old   September 10, 2009, 03:51
Ahh OK, I missed that, it should be grad(alpha1) in both cases but as the scheme is set the same as the default it won't make any difference. I will correct this in 1.6.x.
Thanks
H
alpha, alpha1, gamma, interdymfoam, interfoam
Getting a concentration field around a bubble in InterFoam azman OpenFOAM Running, Solving & CFD 3 June 7, 2022 05:21
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 07:36
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 22:58
Alpha to be phased out Heiko Gerhauser Main CFD Forum 17 July 25, 2001 15:40
Determining alpha and beta for porous baffle Liaqat Khan Siemens 1 October 27, 2000 05:44
