Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Failed to compile sprayFoam solver clone
Like Tree1Likes
  • 1 Post By Shawn Kong
Old   April 14, 2023, 17:58
Default Failed to compile sprayFoam solver clone
Xiang'en Kong
Shawn Kong is on a distinguished road
I want to create a mySprayFoam solver on the base of sprayFoam solver.
So I created $FOAM_USER_APPBIN/applications/solvers directory and copied to original solver into this directory.
Changed the .C filename to mySprayFoam and updated the Make/files to :
mySprayFoam.C
EXE = $(FOAM_USER_APPBIN)/mySprayFoam and did not make any other changes.
However when I try to compile the solver with wmake I get the following error:
Making dependency list for source file mySprayFoam.C
could not open file correctPhi.H for source file mySprayFoam.C due to No such file or directory
g++ -std=c++11 -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -Wno-attributes -O3 -DNoRepository -ftemplate-depth-100 -I. -I../reactingParcelFoam -I../../compressible/rhoPimpleFoam -I/home/xek/OpenFOAM/OpenFOAM-8/src/finiteVolume/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/sampling/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/MomentumTransportModels/momentumTransportModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/MomentumTransportModels/compressible/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/ThermophysicalTransportModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/ThermophysicalTransportModels/psiReactionThermo/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/lagrangian/basic/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/lagrangian/intermediate/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/lagrangian/spray/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/lagrangian/distributionModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/specie/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/basic/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/thermophysicalProperties/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/reactionThermo/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/SLGThermo/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/thermophysicalModels/chemistryModel/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/radiationModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/ODE/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/regionModels/regionModel/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/regionModels/surfaceFilmModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/combustionModels/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/dynamicFvMesh/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/meshTools/lnInclude -IlnInclude -I. -I/home/xek/OpenFOAM/OpenFOAM-8/src/OpenFOAM/lnInclude -I/home/xek/OpenFOAM/OpenFOAM-8/src/OSspecific/POSIX/lnInclude -fPIC -c mySprayFoam.C -o Make/linux64GccDPInt32Opt/mySprayFoam.o
mySprayFoam.C:116:26: fatal error: correctPhi.H: No such file or directory
116 | #include "correctPhi.H"
compilation terminated.
make: *** [/home/xek/OpenFOAM/OpenFOAM-8/wmake/rules/General/transform:26: Make/linux64GccDPInt32Opt/mySprayFoam.o] Error 1
So what can I do with that?
Best,
Xiang'en
sr786 likes this.
Shawn Kong is offline   Reply With Quote
Old   February 13, 2024, 12:05
ASR
sr786 is on a distinguished road
Hi I have a similar issue using OpenFOAM-9 (LINUX distribution: OpenSUSE-15.4) but it is with compiling a new turbulence model for SSG and LRR. I followed same procedure as I did with compiling new turbulence model for two equation models such as kEpsilon and kOmega (which worked).
Did you manage to resolve this issue?
sr786 is offline   Reply With Quote
Old   February 14, 2024, 04:14
Domenico Lahaye
dlahaye is on a distinguished road
Make sure to use the OpenFoam distribution for which sprayFoam was developed?
Not sure which version of OpenFoam this is.
dlahaye is offline   Reply With Quote
Failed to compile sprayFoam solver clone blttkgl OpenFOAM Programming & Development 1 October 9, 2017 05:04
fluent divergence for no reason sufjanst FLUENT 2 March 23, 2016 17:08
Transient boundary conditions Jarrod Sinclair (Sinclair) OpenFOAM Running, Solving & CFD 133 May 6, 2015 07:21
DeardorffDiffStress turbulence model Zuixy OpenFOAM Running, Solving & CFD 0 November 14, 2011 09:44
[OpenFOAM] ParaView/Parafoam error when making animation Disco_Caine ParaView 6 September 28, 2010 10:54
