Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Problem with pressure on processor patches with buoyantBoussinesq solvers
Like Tree2Likes
  • 2 Post By SaraMar
Old   October 25, 2018, 06:50
Default Problem with pressure on processor patches with buoyantBoussinesq solvers
Sara Marković
SaraMar is on a distinguished road
I have been using buoyantBoussinesqPimpleFoam to simulate a fluid with two layers of different density in a box with the moving lid. The solution is good if I run it in serial, but in parallel there is a strange behaviour of velocities between processor patches. I have found the same behaviour in OpenFOAM 3 and 5 and in buoyantBoussinesqPisoFoam of FOAM-extend 4.
This behaviour appeared in both, laminar and turbulent cases, but in laminar it does not seem to affect the solution, where in turbulent, both LES and RAS, it becomes dominant part of the solution.
I checked velocities before solving for pressure on the first time step and this behaviour is absent. It is also absent if I switch off gravity term. This leads me to conclusion that the problem is in linear solver for pressure, but it appeared with all linear solvers that I have tested.
I am attaching a test-code which can reproduce this and an images of this behaviour in laminar and with LES.
Any help is welcome!
Best,
Sara
EDIT:
Problem solved on https://develop.openfoam.com/Develop...us/issues/1047 .
wyldckat and Santiago like this.
SaraMar is offline   Reply With Quote
parallel, processor patch
question regarding LES of pipe flow - pimpleFoam Dan1788 OpenFOAM Running, Solving & CFD 37 December 26, 2017 15:42
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 06:35
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 07:50
static vs. total pressure auf dem feld FLUENT 17 February 26, 2016 14:04
Problem with an old Simulation FrankW CFX 3 February 8, 2016 05:28
