Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
Capillary Rise With bubbe inside problem
Like Tree1Likes
  • 1 Post By kmooney
Old   February 8, 2016, 20:15
Exclamation Capillary Rise With bubbe inside problem
Rimsha
block is on a distinguished road
Hi Foamers,
I am trying to model capillary rise in interFoam however during my simulation in a capillary with diameter 1e-3m and height 30e-3 there seem to be bubbles appearing at the bottom which is very strange.
I just wanted to see if anyone has any idea why might that be? please see photo attached to see the bug.
Kind Regards
Rimsha
block is offline   Reply With Quote
Old   February 11, 2016, 14:54
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Hi Rimsha,
Whats your boundary condition settings at the inlet?
kmooney is offline   Reply With Quote
Old   February 11, 2016, 15:51
Rimsha
Hi kmooney
thank you for the reply, i have the following inlet conditions:
alpha.water:
inlet
type inletOutlet;
value uniform 1;
inletValue uniform 1;
p_grh
inlet
type fixedValue;
value uniform 0;
velocity:
inlet
type pressureInletOutletVelocity;
value uniform (0 0 0);
Old   February 11, 2016, 15:52
kmooney's Avatar
Kyle Mooney
I would retry the case with alpha inlet bc as fixedValue 1 (instead of inletOutlet) and see if that helps.
Old   February 11, 2016, 16:57
Rimsha
Hiya,
I have tried that however the deltaT becomes very small and the simulation stops as co max is exceeded.
Therefore i am unable to get a solution.
Kind regards
Rimsha
Old   February 12, 2016, 01:08
kmooney's Avatar
Kyle Mooney
Are you using setFields to set the first few cells in from the inlet to alpha=1? Some simulations have strange startup effects if there is an alpha=1 inlet and the cells just inside are alpha=0.
Lennart.H likes this.
Old   February 12, 2016, 11:26
Rimsha
Yes i am using setFields, are you suggesting i should not use fields or use either one?
[blockMesh] Problem with mesh generation Silvy OpenFOAM Meshing & Mesh Conversion 12 July 12, 2015 17:10
Problem, airflow in a duct with a steel grid inside? maverick1990 FLUENT 3 March 31, 2014 06:00
problem about DPM of a valve inside flowfield chang Fluent Multiphase 0 March 10, 2014 00:01
Query on VOF for Bubble rise Vamsi Main CFD Forum 0 December 22, 2005 01:02
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
