Home > Forums > Software User Forums > OpenFOAM > OpenFOAM Bugs
blockMesh - no spellcheck at convertToMeters;
Like Tree1Likes
  • 1 Post By alexeym
Old   November 21, 2014, 15:03
Default blockMesh - no spellcheck at convertToMeters;
seav is on a distinguished road
Hello.
Today I've sadly discovered there is no spellcheck at function convertToMeters; in blockMeshDict dictionary file.
BlockMesh just read it anyway without any error or information.
ex. converToMeters 0.001; will be read by blockMesh and it wont be actually converted to 0.001 scale.
...otherwise convertToMeters 0.001; will be read too but it will convert to correct scale.
This is in my opinion an error which can give very very bad informations. And can make confusions especially with new users.
Cheers.
seav
Cheers,
seav
"OpenFOAM is like a strict teacher, won't let you through until all is correct or better say until one has understood the sensitivities of a problem." -jaswi
seav is offline   Reply With Quote
Old   November 22, 2014, 17:07
Hrvoje Jasak
Do you have any ideas on how to actually implement this?
Hrvoje Jasak
Old   November 22, 2014, 18:11
Hello Mr Jasak,
In my opinion simple spellcheck a phrase "convertToMeters" before blockMesh does his job should be enough. If the phrase is correct blockMesh should go on and if its not should crash with an error.
Sadly admit, I am not skilled with OpenFOAM programing to give source code.
Cheers,
seav.
Cheers,
seav
Old   November 22, 2014, 18:15
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
Well guess it's a test, change
    // optional 'convertToMeters' or 'scale'  scaling factor
    if (!meshDescription.readIfPresent("convertToMeters", scaleFactor_))
        meshDescription.readIfPresent("scale", scaleFactor_);
to more strict calls.
seav likes this.
alexeym is offline   Reply With Quote
Old   January 3, 2015, 07:24
Retired Super Moderator
Bruno Santos
Greetings to all!
This feature request has now been posted at the following locations:
Best regards,
Bruno
Old   January 3, 2015, 07:49
Thank you for replay.
Cheers,
seav
Cheers,
seav
Old   January 3, 2015, 15:18
Derek Mitchell
derekm is on a distinguished road
if you change the first character t of converttToMeters o a capital C you get an access violation... took a wee while to work that one out.
A CHEERING BAND OF FRIENDLY ELVES CARRY THE CONQUERING ADVENTURER OFF INTO THE SUNSET
derekm is offline   Reply With Quote
Old   January 3, 2015, 16:08
Bruno Santos
I'm unable to reproduce that error. I've tried with OpenFOAM 2.3, 2.1, foam-extend 3.1 and OpenFOAM 1.6-ext, using:
  • converCToMeters
  • ConvertToMeters
  • converttToMeters
Can you provide an exact example file and with which OpenFOAM version you managed to get that?
Old   January 3, 2015, 17:58
Derek Mitchell
  • converCToMeters
  • ConvertToMeters
  • converttToMeters
I'll try to recreate it.. I was just so glad to get rid of the bug I dropped the file pronto ... it was 2.3.1 on OpenSuse 12.3
Old   January 10, 2015, 19:31
Derek Mitchell
nope cant recreate it...
drat..
Is Playstation 3 cluster suitable for CFD work hsieh OpenFOAM 9 August 16, 2015 15:53
[blockMesh] set of xyz data in blockMesh psk OpenFOAM Meshing & Mesh Conversion 12 August 27, 2013 09:37
Blockmesh problem with more than one block sven82 OpenFOAM Pre-Processing 1 June 4, 2013 18:08
Dimensionsproblems SLT-file and blockMesh suitup OpenFOAM Bugs 3 November 19, 2009 04:00
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
