Home > Forums > Software User Forums > OpenFOAM > OpenFOAM News & Announcements > OpenFOAM Announcements from OpenFOAM Foundation
OpenFOAM Foundation releases OpenFOAM® 2.3.1
Like Tree4Likes
  • 4 Post By CFDFoundation
Old   December 10, 2014, 05:14
Default OpenFOAM Foundation releases OpenFOAM® 2.3.1
CFDFoundation is on a distinguished road
The OpenFOAM Foundation is pleased to announce the release of version 2.3.1 of the OpenFOAM open source CFD toolbox. The release coincides with the 10th Anniversary of the first release of OpenFOAM (version 1.0) by the project founders: Henry Weller, Chris Greenshields and Mattijs Janssens.
Version 2.3.1 consolidates the major version 2.3.0 release through a large number of bug fixes and code improvements, included in over 400 code commits and 800 file changes. OpenFOAM v2.3.1 is distributed under the General Public Licence by the OpenFOAM Foundation as:
Version 2.3.1 also contains small, new developments, some of which are listed below. See the version 2.3.0 release announcement for information about the new features in the 2.3 series of OpenFOAM software.
Pre-processing
A new fixedNormalInletOutletVelocity boundary condition (BC) has been added in 2.3.1; the pressureInletOutletVelocity BC now optionally includes a specified tangential component for velocity.
Meshing
snappyHexMesh includes some feature enhancements including allowing empty refinement surfaces and improved feature refinement with parallel running; a new searchableSurface has been introduced called searchableDisk, which defines a circular disk by origin, normal and radius; the Bspline functionality has been reintroduced to blockMesh.
Thermophysical modelling
Support has been added for PengRobinsonGas equation of state.
Turbulence modelling
The kOmegaSST model has been upgraded and support for multiphase operation has been included in the buoyantKEpsilon and continuousGasKEpsilon models.
Multiphase modelling
  • The twoPhaseEulerFoam multiphase solver has been rewritten to be fully conservative in mass, momentum and energy. This development required additions to fvmDdt/fvcDdt to support time derivatives of triples, e.g. . Conservation requires convergence of the equation system, so ‘PIMPLE’ outer correctors have been introduced to the tutorial examples.
  • The driftFluxFoam solver has now replaced settlingFoam, providing the functionality of settlingFoam and more, with the modelling written using OpenFOAM’s standard run-time selection mechanism and including multiple reference frames (MRF).
  • A dynamic mesh potentialFreeSurfaceDyMFoam solver has been introduced with accompanying oscillatingBox tutorial.
Particle methods
Improvements have been incorporated to deal with ‘stuck’ particles and a new Lagrangian turbulence library has been created for the new turbulence modelling structure.
Post-processing
A new vorticity function object has been added in this release.
Other
The run-time code compilation, e.g. using the the #codeStream directive, and systemCall function object are now activated by default in 2.3.1; they can be deactivated by setting allowSystemOperations switch off (= 0) in the global controlDict file in the etc directory of the OpenFOAM installation.
OpenFOAM v2.3.1 was produced by Henry Weller, Mattijs Janssens, Chris Greenshields, Andy Heather, William Bainbridge and Sergio Ferraris.
Thanks to the OpenFOAM enthusiasts who have contributed to a better code through the bug reporting system.
To download OpenFOAM 2.3.1, click here.
wyldckat, romant, Ohbuchi and 1 others like this.
CFDFoundation is offline   Reply With Quote
Old   January 27, 2015, 10:48
Default upgrading to OpenFOAM 2.3.1
iafpython's Avatar
Igor
iafpython is on a distinguished road
Hi all,
I have a question for you; before installing OpenFOAM 2.3.1 should I uninstall or remove the 2.3.0 version, or I might follow the instructions for installing?
By the way, Im having troubles about the alias in the bashrc file. (in my 2.3.0 version)
Igor
iafpython is offline   Reply With Quote
Old   January 31, 2015, 06:54
Retired Super Moderator
Bruno Santos
Greetings Igor,
Note: this is not an "official" answer .
First of all, you should be more clearer on which installation instructions you've followed to install OpenFOAM 2.3.0. According to your username's posting history, you asked about this here: http://www.cfd-online.com/Forums/ope...u-14-04-a.html - and you followed these instructions for installing: http://openfoamwiki.net/index.php/In...u#Ubuntu_14.04
As for the aliases problem you're having, it's explained in detail here: http://openfoamwiki.net/index.php/In...nFOAM_versions
As for the need to uninstall OpenFOAM 2.3.0: it depends on what you want and/or need. If you prefer to keep things simple, then remove the 2.3.0 installation you have got and then install 2.3.1. Nonetheless, if you want to keep 2 or more versions of OpenFOAM installed, then the instructions mentioned for the aliases will help you do that.
As for (sort-of) detailed instructions on uninstalling OpenFOAM, have a look at this FAQ: http://openfoamwiki.net/index.php/FA...ve_OpenFOAM.3F
Best regards,
Bruno
Old   February 7, 2015, 22:29
iafpython's Avatar
Igor
Dear Bruno,
Thanks a lot. Your kindness is superb.As usually.
What I did is :remove the files of the 2.3.0 version and do the standard procedure for installing 2.3.1. All went well fortunately.
What I am trying to do is:
- simulate a buoyancy driven flow (oil) heat by a surface. Simple. Only 1 phase.
-that heat transport on its own will make another surface to rise its Temp. And radiate to the atmosphere.
I'll try first to do it in 2D first. And want to make parallel processing on a robust system of 128 nodes. (PC cluster).
I'm starting the Nagy youtube videos. They are great! !!
Have an advice for me , By no means I am an experienced user...I really would need some help.
Best Regards,
Igor.
Old   February 8, 2015, 06:19
Bruno Santos
Quick answer - have a look at the following threads:
FluiDyna releases Culises 1.1 for GPU-based acceleration of OpenFOAM® FluiDyna GmbH OpenFOAM Announcements from Other Sources 4 February 19, 2014 19:57
7th OpenFOAM Workshop holger_marschall OpenFOAM Announcements from Other Sources 56 October 27, 2012 14:28
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 07:25
OpenFOAM 1.5.x package - CentOS 5.3 x86_64 linnemann OpenFOAM Installation 7 July 30, 2009 04:14
OpenFOAM Install problem masb OpenFOAM 3 May 25, 2009 12:32
