Entry 'castellatedMesh' not found in dictionary |
March 20, 2024, 04:42 |
Izgi Yagiz Gezgin
Rep Power: 2 |
I am trying to run snappyHexMesh for my airfoil however, i got this error: --> FOAM FATAL IO ERROR: [0] Entry 'castellatedMesh' not found in dictionary "/home/yangzo/OpenFOAM/yangzobuntu/run/training/new/system/snappyHexMes And the following error: --> FOAM FATAL IO ERROR: [1] Entry 'castellatedMesh' not found in dictionary "IOstream" I ran "mpirun -np 6 snappyHexMesh -overwrite -parallel". Thanks in advance if anybody can help me solve this! Last edited by yangzo; March 20, 2024 at 04:44. Reason: adding snappyhexmeshdict |
March 20, 2024, 10:34 |
M
Rep Power: 13 |
Not opening docx.
However I assume you do have "castellatedMesh" in your snappyHexMeshDict. In this case your error is most likely coming from a bad syntax. Look for brackets that are not balanced (missing opening or closing brackets) and statements where you might have missed a semicolon. |
March 20, 2024, 10:38 |
Izgi Yagiz Gezgin
Rep Power: 2 |
hi Ato,
Thanks for reply, you`re right it was just a typo, I just found out I didnt use capital letter |
castellated mesh, snappy hex mesh |
Dictionary entry for patch inlet not found - OpenFOAM | sri_0548 | OpenFOAM | 0 | January 28, 2024 09:49 |
[A newbie needs Help] Entry not found in dictionary | Henrique Meier | OpenFOAM Running, Solving & CFD | 0 | November 27, 2021 12:51 |
[Other] Mesh Importing Problem | cuteapathy | ANSYS Meshing & Geometry | 2 | June 24, 2017 06:29 |
8x icoFoam speed up with Cufflink CUDA solver library | kmooney | OpenFOAM Running, Solving & CFD | 42 | November 6, 2012 12:37 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 09:48 |
