Home > Forums > Special Topics > Mesh Generation & Pre-Processing
3d airfoil meshing in icem cfd
Like Tree1Likes
  • 1 Post By sumon
Old   May 8, 2023, 19:16
Default 3d airfoil meshing in icem cfd
Md Daluar Hussain Sumon
sumon is on a distinguished road
Hi Good People,
Is there any way to assign different number of nodes in parallel edges in ICEM? For instance: I want to assign different number of nodes on the edges of suction (i.e., 150) and pressure (i.e., 100) sides of an airfoil. I have tried using:
Blocking -> Pre-mesh Params -> Copy Parameters -> To selected edges.
But it doesn't work! I don't know what I am missing. Is there any other way to do it ICEM?
Your kind help will be highly appreciated. Thanks!
sumon is offline   Reply With Quote
Old   May 9, 2023, 08:46
M
AtoHM is on a distinguished road
Can you draw a sketch of such a block and ... see why that does not work?
What you can do is create a degenerate/collapsed block. Add an additional block line and collapse it on the pressure side of the airfoil. The collapsing is shown here on page 204: https://fernandobatista.net/educatio...DF/itut110.pdf
AtoHM is offline   Reply With Quote
Old   May 9, 2023, 14:53
Thanks for your reply and suggestion. I will check it out and try. Here I have attached two views of my current existing blocks. It has simply five blocks as seen in the images. Your further suggestions based on my existing blocks in this regard might be very helpful for me.
AtoHM likes this.
Old   July 5, 2023, 07:17
Chrowale
mluckyw is on a distinguished road
I'm not sure if this still useful or not, but in order to make a different number of nodes with a block that was created initially with parallel edges, you need to use permanently delete block on the airfoil. Because deleting blocks without checking the option permanently delete it, it would just go to VORVN.
mluckyw is offline   Reply With Quote
airfoil 3d, icem 3d, structured grid
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points Simurgh OpenFOAM Meshing & Mesh Conversion 4 August 25, 2023 08:58
3D Airfoil ICEM Hexa Meshing Skewness Issues AamirSultan Mesh Generation & Pre-Processing 0 December 1, 2018 17:16
[ICEM] problem with meshing in icem cfd saurabhjoshi2011 ANSYS Meshing & Geometry 13 March 12, 2013 12:27
[Other] Ansys Meshing vs Ansys ICEM CFD JuPa ANSYS Meshing & Geometry 5 September 19, 2012 10:48
[ANSYS Meshing] Icem 2d meshing for multi-element airfoil tetsuya ANSYS Meshing & Geometry 0 November 10, 2011 06:19
