Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Dynamic mesh using snappyHexMesh
Like Tree1Likes
  • 1 Post By AtoHM
Old   June 29, 2022, 11:53
Unhappy Dynamic mesh using snappyHexMesh
Abhinav Dixit
Abhinav Dixit is on a distinguished road
Hello everyone,
Greetings!
Currently, I am struggling in generating a dynamic mesh using SnappyHexMesh. Geometry consists of the following three parts:
1. Reactor: cylindrical, dia: 30 cm height 80 cm
2. Blade: 4 wing blade, dia 10 cm with a blade twisted at an angle
3. AMI
As the geometry is to scale to the experiment that was designed by the department.
when the meshing finishes, I get a lot of unwanted cells in one of the directions.
From the outside outside.JPG it looks fine and also when snapped in the X direction Xplane_snap.JPG. But when I snap it in Y direction I see unwanted cells which are some how linked to the AMI Yplane_snap.jpg.
Please see the snappyhexmeshdict attached as well snappyHexMeshDict.txt
Could anyone explain what can be done to clean the mesh? Things that have already been tried:
1. refining and coarsing of mesh
2. turning off Decompose polyhedra in paraview.
Thank you in advance any help would be appreciated.
Kind regards
Ab
Abhinav Dixit is offline   Reply With Quote
Old   July 20, 2022, 05:18
M
AtoHM is on a distinguished road
You need to use the crinkle option on clips and slices to avoid this representation. Good news: your mesh is fine, its just visuals.
yangzo likes this.
AtoHM is offline   Reply With Quote
dynamicmesh, snappyhexmesh 3d, snappyhexmesh cells
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 06:14
Update of the variables after dynamic mesh motion. gtg258f OpenFOAM Programming & Development 9 January 18, 2014 11:08
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
