Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Problem with structured mesh in GMSH
Like Tree1Likes
  • 1 Post By PenPencil
Old   July 21, 2021, 11:51
Default Problem with structured mesh in GMSH
Andrea_p is on a distinguished road
I am new in the forum and in GMSH. I don't understand why Gmsh turns my structured mesh into an unstructured one. I attach the file. geo in extension .txt. Thanks in advance for your help.
Regards,
Andrea
Andrea_p is offline   Reply With Quote
Old   July 21, 2021, 16:22
Icaro A. Carvalho
PenPencil is on a distinguished road
Gmsh requires all surfaces to have at most 4 constituent points/lines to provide a structured mesh. You have to subdivide your geometry in surfaces where you have no more than this number of points/lines.
PENGGEGE777 likes this.
PenPencil is offline   Reply With Quote
Old   July 21, 2021, 16:25
Icaro A. Carvalho
Besides, you have to recombine all your surfaces. Please check the tutorials from Gmsh. There you can see how to recombine the elements to get a structured mesh. In short, you have to transfinite your surfaces and then recombine. Best of luck.
Old   July 21, 2021, 17:26
Thanks for your answer, I try and I will let you know
-Andrea
Old   July 22, 2021, 09:01
I can't find the tutorials of Gmsh, have you got any links?
-Andrea
Old   January 21, 2022, 05:04
PENG YAN
PENGGEGE777 is on a distinguished road
-Andrea
Go gmsh website, an example is the following link:
http://gmsh.info/doc/texinfo/gmsh.ht...-element-sizes
PENGGEGE777 is offline   Reply With Quote
gmsh 4.7.1
GMSH: 2D axisymmetric structured mesh mkhm Mesh Generation & Pre-Processing 3 November 5, 2020 19:17
[Gmsh] Gmsh: Structured Mesh problems skrishnamoorthy OpenFOAM Meshing & Mesh Conversion 3 August 9, 2017 23:48
Difficulty when using gmsh to create a structured mesh. Apron Main CFD Forum 0 November 4, 2014 08:06
[Gmsh] gmshToFoam problem: not the same mesh in Gmsh vs. paraview zhernadi OpenFOAM Meshing & Mesh Conversion 8 July 7, 2011 03:28
