Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Convert Tecplot ASCII Grid in "Point" Format to CGNS using tecplot_to_cgns utility
Like Tree1Likes
  • 1 Post By kagoc8
Old   February 12, 2020, 13:51
Default Convert Tecplot ASCII Grid in "Point" Format to CGNS using tecplot_to_cgns utility
kagoc8 is on a distinguished road
I want to convert the grid that is available on NASA TMR for the periodic hill geometry to .cgns format using the tecplot_to_cgns utility available in the cgns toolset.
The grid is stored in a simple point format, with each cell identified using an x,y, and z coordinate. The first few lines of that file are shown below:
TITLE = "hill"
VARIABLES = "x", "y", "z"
ZONE I=197, J=129, K=1, F=POINT
-4.157690192E-09 1.000000000E+00 0.0
3.214285523E-02 1.000000000E+00 0.0
6.428571045E-02 1.000000000E+00 0.0
9.642857313E-02 1.000000000E+00 0.0
1.285714060E-01 9.995964170E-01 0.0
tecplot_to_cgns identifies this file as a valid tecplot ascii file, but fails to write a .cgns.
It does not throw an error, but instead fails to identify any nodes.
The output of the tecplot_to_cgns command is as follows:
./tecplot_to_cgns hill_grid_point.dat hill.cgns
reading Tecplot file from hill_grid_point.dat
writing CGNS data to hill.cgns
zone Zone1:25413 nodes... 0 elements... done
Can anyone with experience with the cgns toolset provide guidance regarding this issue?
Svetlana likes this.
kagoc8 is offline   Reply With Quote
Old   February 18, 2020, 19:24
Svetlana Tkachenko
Svetlana is on a distinguished road
Does it work for a tiny mesh like below?
TITLE = "test"
ZONE I=2, J=2, K=1, F=POINT
0.0 0.0 0.0
0.0 1.0 0.0
1.0 1.0 0.0
1.0 0.0 0.0
Svetlana is offline   Reply With Quote
Old   February 19, 2020, 15:36
No luck for the simple test file you suggested that I try.
File Type: png Screenshot from 2020-02-19 11-35-02.png (26.8 KB, 13 views)
Old   February 19, 2020, 19:41
It does work however, when going back and forth between .cgns and Tecplot ascii when using the "bump.dat" sample .cgns file available here: https://cgns.github.io/CGNSFiles.html
File Type: png Screenshot from 2020-02-19 15-36-54.png (32.0 KB, 7 views)
Old   February 20, 2020, 19:43
Svetlana Tkachenko
Can you paste the bump.dat headers (first 4-5 lines of the bump.dat file)? I will be able to test this in my Tecplot in the next few days, but not today.
Old   February 20, 2020, 21:14
The header looks like this:
TITLE = "bump"
VARIABLES = "X", "Y", "Z"
ZONE T="Zone 1", N=36562, E=18000, F=FEBLOCK, ET=BRICK
-3.19885 -3.19885 -2.99627 -2.99627 -2.80402
-2.80402 -2.62157 -2.62157 -2.44842 -2.44842
-2.28410 -2.28410 -2.12816 -2.12816 -1.98017
-1.98017 -1.83972 -1.83972 -1.70644 -1.70644
-1.57995 -1.57995 -1.45991 -1.45991 -1.34599
-1.34599 -1.23787 -1.23787 -1.13527 -1.13527
-1.03791 -1.03791 -0.945502 -0.945502 -0.857809
-0.857809 -0.774587 -0.774587 -0.695608 -0.695608
-0.620656 -0.620656 -0.549525 -0.549525 -0.482022
-0.482022 -0.417960 -0.417960 -0.357164 -0.357164
-0.299467 -0.299467 -0.244713 -0.244713 -0.192750
-0.192750 -0.143437 -0.143437 -0.0966375 -0.0966375
-0.0522244 -0.0522244 -0.0100757 -0.0100757 0.0299240
0.0299240 0.0678843 0.0678843 0.103909 0.103909
the full file is on the cgns site mentioned above. Thanks for your help!
Old   February 20, 2020, 23:36
Svetlana Tkachenko
Here I've modified the small file above to include the zone title:
TITLE = "test"
ZONE T="myzone", I=2, J=2, K=1, F=POINT
0.0 0.0 0.0
0.0 1.0 0.0
1.0 1.0 0.0
1.0 0.0 0.0
Could you possibly check whether this works? The other difference is BLOCK datapacking, here is an example for it:
TITLE = "myDataSet"
VARIABLES = "X", "Y", "Z", "U"
ZONE I=5, DATAPACKING=BLOCK
2 3 5 6 7
4 9 25 36 49
0 0 0 0 0
0 1 4 1 0
Please check whether any of this works.
Thanks and regards,
Svetlana
Old   February 21, 2020, 13:24
No luck with either of these approaches.
File Type: png Screenshot from 2020-02-21 09-24-00.png (63.8 KB, 11 views)
cgns file read, cgns to tecplot
On grid independent solution for pulsatile flow David FLUENT 5 March 25, 2022 04:33
Tecplot output format in 2-D cartesian grid jinwon park Tecplot 5 April 7, 2008 07:28
2d CGNS grid for use with ensight zonexo Main CFD Forum 0 May 16, 2006 22:37
Combustion Convergence problems Art Stretton Phoenics 5 April 2, 2002 06:59
Grid Independent Solution Chuck Leakeas Main CFD Forum 2 May 26, 2000 12:18
