Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Salome local refinement
Like Tree1Likes
  • 1 Post By LeeRuns
Old   September 2, 2018, 19:03
Default Salome local refinement
fede32's Avatar
Federico Agustín Caccia
fede32 is on a distinguished road
I'm trying to generate a mesh with local refinement in salome. Using Mesh-> Create Mesh->Algorithm: NETGEN 1D-2D-3D, and then, I select NETGEN 3D Paramenters. In Local sizes tab I select On vertex (after selecting the desired vertex) and I change the local size to 0.1 times the default local size. I Apply, Close and then compute the mesh.
But when I inspect the mesh, I realize that there is not local refinement. Anybody knows what am I doing wrong?
fede32 is offline   Reply With Quote
Old   October 5, 2018, 15:07
LeeRuns is on a distinguished road
Maybe try selecting a couple of vertices in the cells you want to perform refinement on.
fede32 likes this.
LeeRuns is offline   Reply With Quote
loca, mesh 3d, refinement, salome
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
