Mandeep Shetty
Rep Power: 10 ![]() |
What is a mesh topology? I have read this term being used in a lot of articles, but could not understand its intuitive meaning. And why is topology called a global property? Also, what does topology mean wrt CFD analysis anyways? Thank you.
Colinda
Rep Power: 14 ![]() |
In general mesh topology means the structure of the mesh or in other words the global characteristics of the mesh:
- is it structured or unstructured? - which type of elements in which regions (e.g. full-hexahedral in the regions near solid walls and hex-dominant elsewhere). - For structured meshes the topology also often refers to the way the structured mesh is oriented and how the boundaries of each block is connected to a boundary of the same block (e.g. in an O-topology) or to the boundary of other blocks. The choice of topology can be important to obtain a good quality mesh (e.g. high orthogonality) and hence is relevant for the CFD analysis. The influence of the topology reduces with a reduced cell size. |
Rep Power: 8 ![]() |
Geometry = The 3D coordinates of the the mesh points.
Topology = connectivity between different points to form faces, edges, ...etc. Last edited by anon_q; July 15, 2019 at 14:13. |
mesh, topology |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
[ICEM] Multiblocking mesh for land topology | Anwer | ANSYS Meshing & Geometry | 0 | June 24, 2016 20:04 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
Faces during change of topology in the mesh | virginie_e | OpenFOAM Running, Solving & CFD | 3 | August 15, 2009 13:32 |
