Home > Forums > Special Topics > Mesh Generation & Pre-Processing
Mesh generation for labyrinth seal
Like Tree1Likes
  • 1 Post By MangoNrFive
Old   February 17, 2018, 14:51
Default Mesh generation for labyrinth seal
Sumanth Bhat
Sumanth Bhat is on a distinguished road
Can anyone suggest me how I can mesh the labyrinth seal shown below using Ansys Mesh or ICEM CFD.. I have attached the geometry size and no of divisions below..
Sumanth Bhat is offline   Reply With Quote
Old   February 19, 2018, 11:27
Philipp Wiedemer
MangoNrFive is on a distinguished road
I would use 4 blocks in circumferential direction as O-grid-Topologie and in plane a H-grid-Topologie as shown in the Picture below (red blocks removed).
MangoNrFive is offline   Reply With Quote
Old   February 21, 2018, 12:52
Sumanth Bhat
Thanks :-) Will try it out. One more doubt.
In ANSYS MESH, suppose if we slice our fluid domain into number of parts and later if we make sliced parts as a single part, will it affect our results. Should we create interface in slover?
Old   February 21, 2018, 13:25
Philipp Wiedemer
I don't quite understand, can you explain a bit more?
Old   February 22, 2018, 02:07
Sumanth Bhat
I have provided detailed procedure along with the picture. Go through it. (Pic sequence = pic #1 --> #2 --> #3 --> #4 )
Old   February 22, 2018, 06:06
Philipp Wiedemer
I'm not familiar with that program, maybe someone else can give insight. But it seems to me that it shouldn't make a difference.
Sumanth Bhat likes this.
Old   February 22, 2018, 12:58
Sumanth Bhat
Thanks.. Waiting for suggestions from other members
Old   March 6, 2018, 05:15
Default Meshing
Sumanth Bhat
Hey. I tried with technique you have suggested but failed to get mesh. I tried to find solution in Internet. But didn't get required answer. Can you please explain in detail How to mesh that geometry in ICEM CFD. It would be immense help if you do so. (if possible also suggest some materials and videos which can helpful to get that mesh.)
Old   March 8, 2018, 07:34
Philipp Wiedemer
I can only tell you how i would do it in ICEM since i don't have any experience with the program you're using.
I would start with a quarter of the grid (90°-Segment) split that block according to the picture i posted and remove the red blocks. Then associate your 90°-mesh-segment to a 90°-segment of your geometry. After that mirror it two times to get a 180°-Segment and then your final 360°-Segment.
Another thing, are you sure you need a 360°-model. If the geometry and the boundary conditions are axialsymmetric you can probably just use a small segment with periodic boundary conditions on the sides.
Old   April 11, 2018, 15:33
Sumanth Bhat
Thanks alot, I got it. Yes! I wanted to analyse 3D model. So I used 3D model. Thanks for suggestions. I tried same way as you said I got the perfect mesh.
Now I am trying to mesh another 3D model and facing a new error. I have made a 3D model of another geometry (Fig 1-2D Geom) in SpaceClaim (Fig 2-3D model).
While importing that geometry into ICEM CFD I cannot see Inlet surface even when I check surfaces in ICEM CFD (Fig 3-ICEM CFD). In Spaceclaim I can see inet Surface (Fig 2-3D mod), but can't see that in ICEM CFD after importing. Same error happens when I tried modelling it in design modular and importing it to ICEM CFD.
What is this error how to resolve it. Please someone throw some light on it and please provide the solution for this error.
Waiting for some positive answers at the earliest.
Old   April 12, 2018, 11:54
Default Questions regarding new options in ICEM CFD
  #11
Sumanth Bhat
When I import geometry in ICEM-CFD using IGES/STEP format, in the left window, I can see a some new options, " 1. Bodies " and " 2. Fluid_1_1_MATPOINT ". [Fig 1]
What is the meaning of these two options?
When I share geometry from Design Modular, these two options will not apper on the window. Why so?
In Fig 2, While blocking, Which option I have to choose to create blocking of my fluid domain.?
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
unstructured mesh generation with strictly constrained boundary in simple space goujl Mesh Generation & Pre-Processing 0 January 29, 2015 11:44
[ANSYS Meshing] Question about mesh generation learning lnk ANSYS Meshing & Geometry 2 July 7, 2012 07:45
ISAAC code mesh generation morteza08 Main CFD Forum 0 June 15, 2012 10:26
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
