Home > Forums > Special Topics > Mesh Generation & Pre-Processing
GMSH extrude a boundary layer from an unstructured Mesh
Like Tree3Likes
  • 3 Post By Hillie
Old   February 15, 2017, 00:24
Default GMSH extrude a boundary layer from an unstructured Mesh
Hilbert
Hillie is on a distinguished road
Hi all,
I was faced with the following problem: I have a nice unstructured mesh 2D mesh in GMSH, and I want to extrude this mesh with a certain growth ratio to a 3D mesh. The extrude command in GMSH lets you easily make an extrusion were all the layers are the same height, but making the layer vary in size was the problem.
I have spend most of my afternoon on the problem size I couldn't find any good solution online, and to make sure other don't have to I though I would share the solution I came up with.
A standard Extrusion will go like this:
surfaceVector[] = Extrude{0, 0, thickness}
        Surface{surfacenumber}  ;
        Layer{number of layers};
        Recombine;
With the Layers command you can vary this size of the layers in the following way:
Layers{{number of cells per layer}, {relative thickness of the layer}}
What I have done is to to create an x amount of 1 cell layers , where x is the amount of cells that you want in the extrusion. To do this I have created a little python script.
@author: hilbert
import numpy as np
initial_mesh_height=1*10**-5  #initial mesh height
blh=0.004                 #required height
n=4.0;                   #amount of cells
#solve for the growth ratio r
rtry=np.linspace(0.5, 1.5, 1000)
error=(1-np.power(rtry,(n)))/(1-rtry)-blh/initial_mesh_height
r=rtry[np.argmin(np.abs(error))]
rtry=np.linspace(r-0.1, r+0.1, 1000000)
blh=initial_mesh_height*(1-r**n)/(1-r)   #compute the extrusion height and see if it matches, i.e how good was our solution for r
#print blh
hts=[]   #the place to put cells
layer=[] #a placeholder for the amount of cells per layer , i.e 1
ht=0     #initialize layer height
for i in range(int(n)):
    h=initial_mesh_height*r**i
    ht+=h
    hts.append(ht/blh)
    layer.append(1)
    #print ht/blh
#print hts
#print layer
This is for a simple geometric expansion, i.e the initial cell grows with a growth ratio r each layer. In the script you pop in the initial cell height, the extrusion height and the amount of cells that you want.
the script then computes the growth ratio. Then pop the relative heights hts in the layer command.
As an example with the inputs as given it gives
layer=[1, 1, 1, 1]
hts=[0.10803802938634398, 0.28089887640449435, 0.55747623163353499, 1.0]
In you then give:
Layers{{1, 1, 1, 1}, {0.10803802938634398, 0.28089887640449435, 0.55747623163353499, 1.0}}
Hope it helps ,
Cheers
Hillie is offline   Reply With Quote
Old   June 22, 2017, 18:20
Default Decreasing cell heigh
Malgorzata
chomikzimon is on a distinguished road
Hi!
Thank you for your post. It is very helpful. Could you let me know if it is possible to have the boundary layers with extrusion but decreasing in height? Simply reversing the layer height in Gmsh does not seem to work.
Thank you for your time!
chomikzimon is offline   Reply With Quote
Old   July 7, 2017, 04:38
Hilbert
He,
With the extrude command you can't since the heights needs to be increasing:
, see http://gmsh.info/doc/texinfo/gmsh.html#index-extrude, section 6.3.2
Can't you use a symmetry condition to avoid having to simulate a full boundary layer?
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
[ICEM] 3D Dynamic Mesh - Boundary layer mesh issues nathanricks ANSYS Meshing & Geometry 0 September 23, 2015 06:14
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
[snappyHexMesh] Boundary layer in a pipe Clementhuon OpenFOAM Meshing & Mesh Conversion 6 March 12, 2012 13:41
[Gmsh] Import problem ARC OpenFOAM Meshing & Mesh Conversion 0 February 27, 2010 11:56
