Pressure constant B.C. in fractional step method
Like Tree5Likes
  • 1 Post By FMDenaro
Old   April 10, 2012, 04:31
Unhappy Pressure constant B.C. in fractional step method
Amin Shariat KHah
amin144 is on a distinguished road
Hi everyOne
As we know pressure in fractional step method is not real pressure and it's pressure-like variable as we see in every reference. and beside this for this pressure every where B.C. is dp/dn=0 .
with this point how we can use pressure constant B.C. in this method? It's like the other method for example SIMPLE-like methods? dp/dn=0 doesn't make any problem?
thanks for your attention
amin144 is offline   Reply With Quote
Old   April 10, 2012, 07:52
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by amin144 View Post
Hi everyOne
for example in the pressure-free method (Moin & Kim) a constant pressure outlet gives you (one-dimension x, second order discretization)
( (dp/dx)i+1/2 - (dp/dx)i-1/2 )/dx = (1/dt) ( (u*)i+1/2 - (u*)i-1/2 )/dx (1)
with the general condition provided by the Hodge decomposition
(dp/dx)i+1/2 = (1/dt) ( (u*)i+1/2 - (un+1)i+1/2 )
Generally, you physically know and prescribe the velocity un+1 at the boundaries and rewrite the pressure equation as:
( (dp/dx)i-1/2 )/dx = (1/dt) ( (un+1)i+1/2 - (u*)i-1/2 )/dx
Now, you have to use Eq.(1) and (2) in the same congruent way but prescribing the constant pressure (that is you have to prescribe something in the LHS of Eq.(2)). Be carefull in the (un+1)
amin144 likes this.
FMDenaro is offline   Reply With Quote
Old   April 10, 2012, 12:08
Amin Shariat KHah
Hi again dear Filippo
thanks very much
You are very professional in this method
understanding your explanations and equations is hard for me
Can you explain me easy like Pierc CFD book and in the form of this book?
you are professional and your explanations is professional too
Old   April 10, 2012, 12:18
thanks very much
what is the issue you have not understood?
amin144 likes this.
Old   April 10, 2012, 14:47
Amin Shariat KHah
Thanks again very very much dear Filippo
If I be right your text mean that we know P(i+1) (from pressure constant boundary) and (u*)i+1/2 so we derive p(i) from eq(1) and after we can derive u(n+1) from eq(2) ?
If I'm wrong I'll appreciate you if you explain me what should I do step by step.
I have another question
why you vanished (dp/dx)i-1/2 in eq(3) if this is for outlet?
In outlet we have (dp/dx)i+1/2=0 . am I right?
Old   April 10, 2012, 16:34
Sorry, I was wrong in copying and pasting the LHS of (3), it writes
... the Eq.(2) prescribes a relation between the normal component of the pressure gradient, the normal component u* and the normal component un+1. The mathematical problem requires only 1 boundary condition to be well posed, therefore generally one prescribe the physical velocity on the boundary. If you know un+1, then you just substitute the (2) into (1) and get (3), this way you does not prescribe dp/dx=0 on the boundary.
In your case you want to prescribe (p)i+1 with a Dirichlet boundary condition, therefore you can not prescribe the physical velocity. You must use some extrapolation from the interior
amin144 likes this.
Old   April 10, 2012, 17:57
Amin Shariat KHah
1)
If we put eq(2) in eq(3) we will have:
( (dp/dx)i-1/2 )/dx = (1/dt) ( (un+1)i+1/2 -2* (u*)i-1/2 )/dx
it's a little different from eq(3)
2)
why we see in refrences says that dp/dn=0 on boundaries?
3)
so if I will have a interpolation to derive u(n+1) on velocity, where the pressure diffrence between inlet and outlet effect to drive the fluid? only in solving poisson equation for pressure and using value of pressure on boundaries for pressure ? and this work is sufficient to apply boundary condition?
Old   April 10, 2012, 18:21
1)
2)
3)
1) put (dp/dx)i+1/2 = (1/dt) ( (u*)i+1/2 - (un+1)i+1/2 ) into the LHS of
and will get
2) dp/dn = 0 is sometimes referenced but it is not really exact... however, the Neumann homogeneous condition applied on Eq.(2) will drive to u* = un+1 and the equivalence with Eq.(3) exists. For this reason you read in literature this condition. But when you compute the normal pressure gradient on the boundary with dp/dn=0, or dp/dn = (1/dt) (u* -un+1), the solutions are different
3) need to considere the extrapolation also in the momentum quantity. You must verify at the end of the steps that Div Vn+1 = 0 also on the cell at outlet
amin144 likes this.
Old   April 10, 2012, 18:43
Amin Shariat KHah
1) you are right like always. I guess I,m being crazy slowly
2) so this B.C. (dp/dn=0) make unexact results? what should do?
3) satisfying Div(Vn+1)=0 need only more itteration or any other yhing?
Old   April 10, 2012, 18:47
dp/dn = 0 is an approximation congruent to a boundary layer approximation ... but can lead to some problems, that is largely discussed in literature.
the divergence-free constraint is satisfied at machine accuracy in the Exact Projecton Method and at the level of the local truncation error in the Approximate Projection Method. Generally, EPM is for second order accurate discretization on staggered grids, APM is on non-staggered.
amin144 likes this.
Old   April 10, 2012, 18:58
Amin Shariat KHah
Thanks your perfect answers
Comparing between the Fractional step method and the SIMPLE method ghlee Main CFD Forum 1 April 10, 2012 17:59
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
fractional step method Fuka Main CFD Forum 1 March 23, 2006 18:01
pressure Poisson equation in fractinoal step metho Rui Main CFD Forum 6 October 15, 2000 05:57
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
