Ghost cells
Like Tree3Likes
  • 3 Post By Jaswant
Old   September 12, 2005, 12:25
Default Ghost cells
Ruben
Hi
I am solving the 2D Incompressible N-S eq using the FVM. I have read that in order to set the Boundary Conditions I could use Ghost cells. How are this cells? How may I implement them?
Thanks in advance,
Ruben
Old   September 13, 2005, 10:05
Default Re: Ghost cells
Jaswant
Hi Ruben!! The ghost cells are nothing but the cells falling outside of boundary. In order to implement boundary conditions, you will need some cells outside the boundary. here is an example: suppose you want to write a central difference formula for d2U/dx= (Ui+1-2Ui+Ui-1)/(2dx). So when you will write this difference formula for cell 1. You will need a cell Ui-1. This cell will fall outside of the boundary. This cell is usally called as ghost cells. Ghost cells are determiined from boundary conditions. for example if your boundary is a solid wall, then you just this ghost cell to zero. Or you can get it by some interpolation in other boundary conditions. Hope this helps. Jaswant
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 20:43
physical boundary error!! kris Siemens 2 August 3, 2005 01:32
