Energy spectra
Like Tree4Likes
  • 3 Post By sbaffini
  • 1 Post By arunsmec
Old   February 29, 2012, 20:27
Default Energy spectra
Yong Wang
ywang is on a distinguished road
Hi, everyone
I have simulated turbulent channel flow with Re_tau=180. The mean velocity and stresses profiles agree with those in Kim, Moin and Moser's paper (JFM 1987, vol 177, pp 133-166). Now, I have problem to plot the one-dimensional spectra.
Taking the spectrum E_uu (k_x) for example. I calculated it with the following steps:
1. Output the 2D velocity field at y+ = 5, and then obtained uu(x,z).
2. With a given z, such as z=0, I performed FFT for uu(x,0) and obtained uu(k_x) at z=0.
3. Averaged uu(k_x) over all z.
The obtained spectrum was much different from the one in reference. However, I think the sharp of the profile is right.
I know there should be something wrong in my steps. And, the E_uu and k_x still need to be normalized by some reference variables, but I don't know how to choose them.
Any help from you would be appreciated. Thanks.
Yong
ywang is offline   Reply With Quote
Old   March 1, 2012, 07:43
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
Hi Yong,
the procedure you described is correct, for a given distance from the wall (say y*) you take your Nz (taken in the transverse coordinate direction) velocity vectors (say x velocity component along the x coordinate), FFT and average them (each coefficient is the average over the Nz ones).
It seems to me that the problem is in the proper "normalization".
I suggest you to check your spectral routine toward some test sin functions
sbaffini is offline   Reply With Quote
Old   March 1, 2012, 15:04
Yong Wang
Originally Posted by sbaffini View Post
Hi Yong,
Hi Sbaffini,
Thanks for your reply. Yes, the key point is to find out the way to normalize k_x and E_uu.
I think there should be some ones who have simulated the same flow in this forum, as Kim's paper is seen as a benchmark for turbulent flow. I searched and read corresponding threads, but didn't find out the way.
Old   March 1, 2012, 15:26
sbaffini's Avatar
Paolo Lampitella
Ok, this morning i was too lazy to check my routine. Now i did it, you can find it attached. It works for MATLAB and, given the velocity field along a direction, it provides you with the correct abscissa and the coefficients to be averaged.
Just to be sure, this is the database we are talking about:
http://turbulence.ices.utexas.edu/da...n180.xspec.178
File Type: txt spectra.txt (416 Bytes, 242 views)
Old   March 1, 2012, 15:39
Yong Wang
Thanks very much. Yes, I am using the data from the same website as the reference. I am comparing the spectra at y+=5.
I am using Qtiplot to perform FFT and don't have Matlab now. I will have a try. What are the characteristic parameters used for normalization?
Old   March 1, 2012, 17:37
sbaffini's Avatar
Paolo Lampitella
According to my memory there are no parameters used for normalization. However, the code you are using to perform the FFT may use some kind of windowing (like the Pwelch mentioned in the file). While this can be useful or even required for several reasons, this does not apply in this case because would invalidate the comparison (and you already average your coefficients in time and transverse directions, so it is not needed).
Old   March 8, 2012, 21:24
Yong Wang
Hi Sbaffini,
Thanks very much. Finally, I didn't compare my sepctra with those from Kim's paper. I just calculated the Komlogorov length scale eta, and plotted E_uu via k*eta.
Old   May 18, 2017, 06:30
Aru
arunsmec is on a distinguished road
Yong
Hi Yong,
I understand this is a very old post. But this is the only one I could find here which is relevant to what I am doing.
Are there any references for this procedure to calculate 1D spectrum?
otroconis likes this.
arunsmec is offline   Reply With Quote
Old   August 12, 2017, 07:19
Ansel
Ansel001 is on a distinguished road
Have you ever tried check your spectral routine toward some test sin function?
Ansel001 is offline   Reply With Quote
energy spectra from LES simulations kumar OpenFOAM Post-Processing 2 February 23, 2016 13:25
Obtaining Energy Spectra from Physical variables CFDtoy Main CFD Forum 0 September 19, 2006 02:44
Energy Spectra! Murthy FLUENT 0 December 26, 2005 08:42
Energy Spectra! Murthy Main CFD Forum 0 December 26, 2005 08:41
turbulent energy spectra ulrich bieder Main CFD Forum 8 June 25, 1999 11:27
