time step for incompressible flows
Like Tree1Likes
  • 1 Post By Márcio Ricardo
Old   August 22, 2005, 07:54
Default time step for incompressible flows
Suriyanarayanan
hi,
I am working on incompressible flows and would like to know how time step based on convective and diffusive considerations are calculated. I consulted few papers, but there are not much details about this. I am not interested in the mere formula but also at how it was arrived.
Thanks in advance.
Suriya
Old   August 23, 2005, 01:01
Default Re: time step for incompressible flows
zonexo
I am trying to get the ans too. I am using factional step to solve the unsteady NS eqns. It's a semi implicit mtd ie Adam Bashford 2nd order for convective (explicit) & Crank nicolson 2nd order for diffusive (implicit). It was given in the paper that the CFL condition is
CFL=max(u(i)*delta_t/delta_x(i)) = 1.
So in order to solve the unsteady eqn, delta_t needs to be determined. However, u(i) is unknown. So how can we obtain delta_t?
Supposed we are simulating a lid driven cavity flow, we know that the max vel = 1. hence can we substitute into the CFL eqn to get delta_t?
Is that reasonable?
Old   August 23, 2005, 09:34
Márcio Ricardo
At each time iteration you have a velocity field. u_i is the max absolute value that you get from the field you have just calculated. Another way to calculate your time step:
dt_conv = 1/(u/dx+v/dy) (1)
dt_difus = 1/(2*visc*(1/dx^2 + 1/dy^2)) (2)
dt = coef/(1/dt_conv + 1/dt_difus) (3)
where, in (1), u, v are the largest absolute velocity values you get in each time iteration.
The coef in (3) is a safety factor, usualy <=0.2
-Márcio
o_mars_2010 likes this.
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
Multiple floating objects CKH OpenFOAM Running, Solving & CFD 14 February 20, 2019 10:08
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 01:36
AMG versus ICCG msrinath80 OpenFOAM Running, Solving & CFD 2 November 7, 2006 16:15
