Advection scheme
Like Tree1Likes
  • 1 Post By Michail Kirichkov
Old   July 11, 2005, 22:55
Default Advection scheme
Tanaka
Hi ! Would you please advise which EXPLICIT scheme is best/good for solving pure advection problems that gurantees the mass conservation? Thanking. Tanaka.
Old   July 12, 2005, 00:21
Default Re: Advection scheme
Junseok Kim
If you use conservative advection form, then the mass conservation is gurantted.
Old   July 12, 2005, 00:40
Tanaka
Hi Kim thanx for the quick response. I will use conservative form. But please tell the name of the scheme, which is not diffusive, non-oscilllatory and perfectly conserves the mass. Thankx again, Tananka
Old   July 12, 2005, 00:49
Junseok Kim
ENO or WENO are quite popular these days for the advection scheme. You can look at Chi-Wang Shu's webpage for the references.
http://www.dam.brown.edu/people/shu/pub.html
Old   July 12, 2005, 00:55
Tanaka
Thank you very much Dr. Kim. Would you kindly email me a copy of the code (fortran or c or c++) for any of the these schemes. I want to incorporate in my 3D code. Tanaka, Japan
Old   July 12, 2005, 01:06
Junseok Kim
Send your code to me, then I will add the 2nd order ENO or the 5th order WENO advection scheme and send you back. If possible, send related paper for your code for me to better understand your code.
Kim
Old   July 12, 2005, 02:06
Michail Kirichkov
It seems to me that HLPA scheme by Zhu J. is the best
See article
Low-diffusive and oscillation-free convection scheme // Communication and Applied Numerical Methods, 1991. 7, N 3 225-232
Old   July 12, 2005, 02:08
Tanaka
Thanx a lot for the input, I will check the article regards, Tanaka
Old   July 12, 2005, 02:36
Default reference
Junseok Kim
Journal of Computational Physics 150, 561–594 (1999)
"A High-Order WENO Finite Difference Scheme for the Equations of Ideal Magnetohydrodynamics"
Guang-Shan Jiang and Cheng-chin Wu
Old   July 12, 2005, 03:42
Michail Kirichkov
Dear Tanaka
Unfortunately I have not the article, I myself far away from it. (
But I found description using Google and here is the link
http://www.lkt.iet.ethz.ch/~lakehal/...4/material.htm
see chapter 4
Mike
Old   July 12, 2005, 03:47
  #11
Michail Kirichkov
to be more exact
at the page you open will be
Chapter 1: Introduction to the Course, Navier-Stokes and Heat Convection Equations
Chapter 2: Numerical Thermal Analysis I: Finite Difference Method
Chapter 3: Numerical Thermal Analysis II: Finite Volume Method
Chapter 4: Phenomenology of Turbulence
Chapter 5: Turbulence Modelling
- Choose Chapter 3
- there will be Chapter 4 (in pdf)
- page 56
challenger149 likes this.
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
Advection scheme at sharp gradients sachinthakre CFX 2 July 7, 2010 04:15
Advection Scheme on an C-Grid Mr. Matti Main CFD Forum 0 April 14, 2010 13:19
Advection scheme for combustion simulation AdidaKK CFX 0 January 12, 2010 14:03
Unbounded advection discretisation acarey CFX 4 April 26, 2009 20:05
