Simple Question - or not?
Like Tree1Likes
  • 1 Post By truffaldino
Old   November 14, 2011, 17:14
Default Simple Question - or not?
Florian Ernst
Florian2 is on a distinguished road
I am new to cfd and my question to the members of this Forum seems to be pretty simple:
What shape has an airfoil with maximum lift when drag is abolutly not relevant?
I am searching for this shape for a long time and even thougt about building a small windchannel to get an answer.
Perhaps the answer is extremly simple, but perhaps it is an extremly complicated airfoil consisting of many pieces (e.g. a grid of some kind...)
Let me get more specific:
The air foil has to have max. lift.
The angle of incidence does not matter, air speed does not matter (within "normal" ranges like 5 m/s up to 300 m/s).
So is there any Software out there that could help me? Is there a simple answer?
Florian2 is offline   Reply With Quote
Old   November 14, 2011, 18:12
raj
raj.cfd is on a distinguished road
The airfoil needs to be really thin to obtain maximum lift.
raj.cfd is offline   Reply With Quote
Old   November 15, 2011, 05:15
Florian Ernst
Hi Raj,
thanks for your fast answer!
So a thin airfoil (probably at a high angle) gives maximum lift?
How did you find out that fast?
I always thought the answer would be much more tricky...
Old   November 15, 2011, 07:25
truffaldino's Avatar
truffaldino is on a distinguished road
Thin airfoil is not necessary gives high lift: it could stall at small aoa. The answer is really tricky. I would rather said: strongly cambered airfoil of an optimal thikness (depending on range of Re number) to delay stall.
There is a technique developed by Eppler and Seilig for a rough estimate of airfoil shape with desired characteristics and there is an excellent free software called "x-foil" by Mark Drela from mit (or its version with good GUI called XFLR-5) that has direct and inverse airfoil design tools.
You can see e.g.
http://smartsonde.org/Project/Vehicl...A-2137-802.pdf
http://www.desktop.aero/appliedaero/...lsections.html
Truffaldino
truffaldino is offline   Reply With Quote
Old   November 16, 2011, 13:52
Zachariah Swetky
swetkyz is on a distinguished road
I might suggest perusing "Theory of wing sections: including a summary of airfoil data" by Abbott and Doenhoff. This should help you to understand how camber and relative thickness play a role in airfoil characteristics.
To give you an idea of what is possible, it is said that the 737 wing has a maximum lift coefficient of about 3.2--and very low drag at low angles of attack.
swetkyz is offline   Reply With Quote
Old   November 16, 2011, 13:54
Zachariah Swetky
P.S. XFOIL, mentioned by Truffaldino, is a great tool!
Old   November 17, 2011, 06:32
Yes, with junkers flaps and slats we can reach such Cl's. Unfortunately x-foil analyzes only single-piece airfoil. There is another software by M.Drela (i do not remember the name) which is a multiple foil analog of x-foil, but it is not free (can be sent by M.Drela on request).
With blown/ or bl suction foils one can reach even twice of this.
Old   November 17, 2011, 15:37
Florian Ernst
thanks for all answers so far.
@swetkyz: 3.2 sounds a little small; so what would the lift coefficient be when the angle is at its maximum?
@truffaldino: I tried xfoil allready - but as you said it is only possible to calculate single foils.
What you mean with "blown/ or bl suction"? Is this the technique of sucking in air on top of the wing?
I think multi-foil wings will be my choice; probably the give max lift (when calculated properly).
Again THANKS A LOT for your help!!!
Old   November 17, 2011, 17:29
Zachariah Swetky
You may find "Simulation and Optimization of Flow Control Strategies for Novel High-Lift Configurations" interesting if you are willing to work with slats and flow control. This paper is by Meunier, and it was published in the AIAA Journal in 2009.
Originally Posted by Florian2 View Post
Yes, this is a technique of sucking the boundary layer on the top to delay separation. Some people say that blowing is even more effective.
You can take a look at a book by Bryan Thwaites on incompressible aerodynamics. He has examples of wing with bl suction up to 30% thick with Cl up to 6 or 9.
As for max Cl without suction devices, Antonov-70 has max Cl=7.2 with slats and flaps only: you can look
http://www.youtube.com/watch?v=PdqMHJJDiFM.
As for software: there is a fast software MSES/MISES by Mark Drela (this is a multiple airfoil x-foil). But it you have to ask M.Drela for acopy.
You could also try Fluent, of course, if you are at large reynolds numbers and flow is almost fully turbulent: Just use S-A turbulence models with multiple airfoils.
In general, when you are at low Reynolds numbers, PDE based CFD software like Fluent cannot handle transition and separation bubbles (in spite of a lot of publicity of new sst transitional models) without a huge user input and comparison with experiments.
swetkyz likes this.
Old   November 17, 2011, 17:48
I have also found a nice video on youtube on bl succion airfoil used by J.Y. Cousteau as a sail which has 5 to 6 times max Cl of an ordinary sail:
http://www.youtube.com/watch?v=X5E0HDBM4xA
Simple Outlet Question m.nichols19 OpenFOAM 3 June 25, 2010 02:44
Simple Question Regarding Symmetry Planes Atella CFX 3 April 11, 2010 07:44
Simple Question Regarding Symmetry Planes Atella Main CFD Forum 0 April 9, 2010 11:58
Question of Anil Date's SIMPLE method universez Main CFD Forum 0 November 18, 2009 21:12
Simple Question Regarding Continuity Closure RC FLUENT 2 March 25, 2004 06:30
