3D NACA 0012 Hydrofoil analysis data
Like Tree1Likes
  • 1 Post By daveatstyacht
Old   October 2, 2011, 04:10
Exclamation 3D NACA 0012 Hydrofoil analysis data
Md. Sayeemuzzaman
sayeem is on a distinguished road
Hi there
I need to find some reference data for 3D NACA0012. Data like Cd, Cl, Cp characteristics of the 3D NACA0012 foil. If you know about any paper or book that has those kind of data please let me know.
I tried to find some on the internet but it was not that helpful.
I will run some test case for the 3D NACA0012 to compare the results to check the robustness of my in-house code.
Thanks in advance
sayeem is offline   Reply With Quote
Old   October 15, 2011, 19:51
Dave
daveatstyacht is on a distinguished road
Sayeem,
Would a 3d NACA 0015 experimental data set be useful instead? I ask because
Free-Stream Characteristics,of a Family of Low-Aspect- Ratio, All-Movable Control Surfaces For Application to Ship Design
by L. Folger Whicker, et al, has a number of such results for various aspect ratios and tip shapes. It was published by NSWCCD formerly David Taylor Model Basin in 1958 (report 933).
Best of Luck
Dave
daveatstyacht is offline   Reply With Quote
Old   October 16, 2011, 12:12
Md. Sayeemuzzaman
well dave that could do the trick
even though 3D NACA would be my first choice but i can do with NACA 0015 (3D) .....
thing is i gotta work with a fin keel from a yacht ....
before doing that i need to check the robustness of my code ...
so i am looking for any popular NACA series data either experimental or theoretical ......
my concern is related to the Cd Cl value of that particular series
so i guess it would be great help if you can provide any data on NACA 0015
thanks in advance
Old   October 16, 2011, 12:53
Dave
Sayeem,
The report I mentioned is available on the internet (google search the title and it shows up). The Cl and Cd are provided and the geometry is a constant section shape so it should be very easy to reproduce. The aspect ratios are of the region of interest for most yacht keels (1 - 3).
Dave
sayeem likes this.
3d naca 0012, drag coefficient, hydrofoil, lift coefficient, pressure coefficient
Lift and Drag Coefficient data for NACA 2412 Airfoil mahbub03 Main CFD Forum 22 May 25, 2014 16:39
Naca 0012 validation, Cd value is too high. Peter88 OpenFOAM 4 January 21, 2014 17:10
How to import NACA 0012 Profile in Gridgen maplepink Main CFD Forum 17 May 7, 2013 14:01
NACA 0012 Case Will Not Converge dancfd OpenFOAM Running, Solving & CFD 6 November 14, 2011 20:09
Problems with flat plate and NACA 0012 Lift/Force Harly FLUENT 0 June 18, 2007 11:02
