July 21, 2011, 03:40 |
Engine manifold flow
Stephen
Good day all
I'm a 4th year engineering student tasked with using CFD to analyze the effects of pressure pulses, scavenging, Helmholtz resonance and so on in the exhaust and inlet manifolds of a 4 stroke IC engine. I do not have a large amount of CFD experience and I was hoping some one could point me in the right direction with concerns to the following, Firstly 1-d vs 2-d vs 3-d, and secondly should one model the entire cylinder with valves including the combustion or would it be sufficient to use a user defined source with varying pressure/mass flow rate's at the inlet or exit of the manifolds? |
July 21, 2011, 03:51 |
what cfd software are you using.
July 21, 2011, 03:54 |
Stephen
Hi chocolate_rain im using fluent, but i also have access to CFX. Im not aware of any advantages of either
engine, exhaust, inlet, pressure pulse |
Flow meter Design | CD adapco Group Marketing | Siemens | 3 | June 21, 2011 09:33 |
Race Engine Air Flow | john grudynski | Main CFD Forum | 0 | May 21, 2006 02:50 |
internal combustion engine port flow simulation | Nyquist | Siemens | 1 | April 29, 2003 04:48 |
IC Engine Flow simulation | Apurv | Main CFD Forum | 2 | February 8, 2000 01:12 |
Question on 3D potential flow | Adrin Gharakhani | Main CFD Forum | 13 | June 21, 1999 06:18 |
