Projection Methods
Like Tree3Likes
  • 1 Post By Petrov
  • 2 Post By valgrinda
Old   June 8, 2011, 23:25
Default Projection Methods
Felipe Hernandez
Petrov is on a distinguished road
I've got a incompressible Navier-Stokes code that works reasonably well (compared to the taylor-green vortex) that uses a pressure-correction time integration method. I want to implement a projection method now, both as a learning experience and to compare the accuracies.
I'm just trying to get a gist of how it works and how it compares to the pressure correction method. From what I understand, I get an intermediate velocity (probably from the old pressure) and then I project the velocity onto divergence-free vector field (by projecting the vector onto the null-space of another matrix?!), then I solve for pressure, and then I make it divergence-free again.
Is this correct? If not, could you describe projection methods to me?
Are there any good (and free?!) articles you could point me to? I have a strict $0 budget for learning CFD.
EDIT:
I also want the method to be accurate at the no-slip boundary conditions so that I can calculate the drag/lift forces. I was reading that projection methods may have a problem with this. Should I look at other options?
rajibroy likes this.
Petrov is offline   Reply With Quote
Old   June 10, 2011, 04:32
Default pjm
Hans Bihs
valgrinda is on a distinguished road
you got the projection almost right, except that the intermediate velocity is calculated with the pressure not included. This is the major difference to SIMPLE type methods: There you include the pressure gradient in the Navier-Stokes equation, so you only need to solve the poisson equation for the pressure correction.
The procedure for the projection method is (with explicit time treatment for the velocities):
- calculate intermediate velocity u* without the pressure gradient
- calculate the divergence of the velocity field, this term will be the right hand side of the poisson equation for the pressure
- discretize the poisson equation for the pressure (trivial for constant density)
- solve the poisson equation iteratively
- correct the velocities (explicitly) with the pressure gradient
- go to next timestep
Here is a link to a paper, where the projection method is used and explained with some detail:
http://wissrech.ins.uni-bonn.de/rese.../croce/lsm.pdf
Here is book, where the discretization of the projection method is described with even more detail:
http://books.google.com/books?id=ehu...page&q&f=false
Cheers
Hans
rajibroy and mostanad like this.
valgrinda is offline   Reply With Quote
Old   June 10, 2011, 10:50
Felipe Hernandez
Wow, those are great resources!
Thanks for your help.
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
projection method sudhakar Main CFD Forum 4 December 8, 2007 02:25
comments on FDM, FEM, FVM, SM, SEM, DSEM, BEM kenn Main CFD Forum 2 July 18, 2004 19:28
free surface flow and projection methods sylvain Main CFD Forum 2 April 26, 2002 10:45
Projection methods ZY Sun Main CFD Forum 9 September 15, 2000 19:00
