turbomachinery coordinates m', theta vs m, r*theta |
April 27, 2011, 17:34 |
Rep Power: 17 |
I am currently writing a small tool which helps me to set up blade geometries in a turbomachine. In order to define the blade camberlines, I am using either a m' / theta (m' = m_prime) or a m/r*theta (m = meridional coordinate) coordinate system. I found both definitions in the handbook of Mises (Drela). Now, I am asking myself which coordinate system is more senseful. I know that some "comercial" tools prefer the m'/theta-definition because it shell be angle-preserving - but why is this not the case with m/r*theta? Can this be proven mathematically? Is the m'/theta coordinate-system senseful if the fluid is _not_ following a streamline (e.g. in a deswirler which turns the flow from radial to axial), as described in the mises manual? Thx for the help. |
September 1, 2013, 23:01 |
A. S.
Rep Power: 17 |
My reply is very late, but may be helpful. Based on my mapping experience based on both m-rtheta and m'-theta. I found that m'-theta is indeed angle preserving and m-rtheta was more dimension preserving. Recently I can across a paper that mentions m-theta transform also. But for my purpose I have used m'-theta for mean-line and m-rtheta for adding thickness and preserving absolute dimensions of LE , max thickness and TE. Best Regards Apoorv |
April 20, 2015, 03:58 |
Hi Apoorv,
This post is a while ago but hopefully you could help me. I am intrested in that coordinate tranformation. After searching a lot in the internet I could not find any usefull decriptions. The most of them only provide the formula m'=dm/r. But all my tries doesent seem to reach any success. Could you help me we that mapping process. Maybe with an simple example. I am very greatfull for your help. Thanks Kam Hi, My reply is very late, but may be helpful. Based on my mapping experience based on both m-rtheta and m'-theta. I found that m'-theta is indeed angle preserving and m-rtheta was more dimension preserving. Recently I can across a paper that mentions m-theta transform also. But for my purpose I have used m'-theta for mean-line and m-rtheta for adding thickness and preserving absolute dimensions of LE , max thickness and TE. Best Regards Apoorv[/QUOTE] |
working in cylindrical coordinates in fluent | Randheer Yadav | FLUENT | 2 | January 18, 2015 17:25 |
Where to find airfoils with more coordinates pts? | KB | Main CFD Forum | 2 | March 24, 2008 00:18 |
Turbomachinery at OpenFOAM Workshop Milan 2008 | hani | OpenFOAM | 0 | March 21, 2008 03:33 |
Coordinate's tranformation | tommy | FLUENT | 0 | February 13, 2004 03:19 |
Calculation in cylindrical coordinates | Franz Wingelhofer | CFX | 0 | December 28, 1999 08:46 |
