Numerical diffusion/dispersion/dissipation
Like Tree2Likes
  • 2 Post By debs
Old   February 28, 2005, 06:41
Default Numerical diffusion/dispersion/dissipation
Hadian
Hi I want to know more about the concept of Numerical diffusion, dissipation and dispersion. can you introduce any reference or link for this. i would like to know about the effect of them in a CFD code individually. Thanks in advance. Hadian
Old   March 29, 2005, 19:33
Default Re: Numerical diffusion/dispersion/dissipation
debs
The numerical dissipation dispersion and diffusion arise depending on the kind of truncation you use . Let us consider an example of a finite difference sequence. When you trauncate the terms greater than dx^2 you have second order accuracy and u have higher order terms like dx^3,dx^4,dx^5.. the odd powered terms givs rise to dispersion of your numerical solution and the even powered terms give rise to dissipation of your numerical solution. When dissipation and dispersion are combined together you get diffusion.
eg. say exact solution is y=a sin(t)
dissipation results in
y=0.8a sin(t)
dispersion results in
y= asin(t+ - q)
diffusion
y= 0.8 a sin(t + - q)
Have a look at any numerical methods book for partial differential equations.
TurbJet and Linmunn like this.
Numerical viscosity due to the MUSCL and HLL coulpled scheme sonsiest Main CFD Forum 0 May 23, 2011 16:37
Numerical Weather Modelling : Time and space resolution issues chriswatt Main CFD Forum 0 February 15, 2011 22:32
Numerical dissipation/difusion in LES Ray FLUENT 2 June 10, 2002 06:15
numerical scheme ado Main CFD Forum 3 October 12, 2000 09:20
New Books and Numerical Software Eleuterio TORO Main CFD Forum 0 December 18, 1998 13:41
