December 25, 2009, 11:28 |
multiphase model, water in air?
B. Selenbas
Rep Power: 16 |
hi everybody,
i study on a multiphase flow model. jet water flow flows from a nozzle into air (g force applied), i want to simulate it with fluent, for a cross section 2D model, all the multiphase model (vof, eulerian and multiphase) work and give a result, but when i try for 3D model, the continuty diverges. it has unstructured mesh and take the courant number default as 0,25. i want to see only the distance that the water goes in air. is there anybody studied this before? thanks for your helps... Bugra |
December 25, 2009, 11:29 |
B. Selenbas
Rep Power: 16 |
And the model is very large, 20 meter length and 15 meter wide, 10 meter height.
Bugra |
December 30, 2009, 23:57 |
modeling multiP jets
hi there,
the problem is not difficult...make sure you tune your solution controls properly ..if you require only the dispersion angle etc..try running SIMPLE with PRESTO scheme for pressure, first order upwinded variables etc...this should give you pretty decent results.. let me know when and where you diverge..what is the error listed? /cfdtoy http://cfdtoy.blogspot.com |
January 1, 2010, 11:12 |
B. Selenbas
Rep Power: 16 |
hi,
thank you for your reply, after 15 iteration, the problem begins to diverge, and contnty is going up, if i let it go, it goes 1e12 and higher, actually, it doesn't give an error, it only runs, but not converges, bugra [IMG]file:///C:/DOCUME%7E1/bugra/LOCALS%7E1/Temp/moz-screenshot-1.png[/IMG] |
B. Selenbas
Rep Power: 16 |
so i couldn't add convergence picture, don't mind the link above
January 1, 2010, 11:28 |
B. Selenbas
Rep Power: 16 |
the error is that;
Error: > (greater-than): invalid argument [2]: wrong type [not a number] Error Object: 1.#inf at 102. iteration Bugra |
January 1, 2010, 15:55 |
MP divergence
#7 | |
Hello bugra,
good that you were able to spot divergence immediately. Now, are you running steady or unsteady model? what kind of multiphase model are you running - VOF or eulerian-eulerian or mixture model? what are your initial conditions? is there turbulence added? what are your solution control settings? Hopefully, we can get something out from here. /CFDtoy Visit http://cfdtoy.blogspot.com Quote:
January 1, 2010, 18:10 |
B. Selenbas
Rep Power: 16 |
hello again,
it's unsteady model (i'm not sure if i use steady, it gives true solution for only dispersion of water in air), i tried steady model too, but it diverged too. i use VoF model, turbulance k-epsilon, water in the pipe is at 1-5 bars static pressure, the upper surface is pressure inlet for air, the outer surface is pressure outlet for air, as i read from tutorials, piso algorithm, all of underrelaxation factors are 1, pressure is "body force weighted", momentum first order, volum fraction "Geo-Reconstruct", tke is first order, and tdr is first order. in addition to this, it' s unstrucured grid. the problem is that, water comes in a pipe to a nozzle and here, it enters into air. water in pipe has between 1 and 5 bars pressure. i wanna to see only the distance that water has gone and the angle of going out from nozzle. thanks Bugra |
January 1, 2010, 21:38 |
divergence
#9 | |
From the log file check which quantity is diverging? continuity, xvel, y vel, k , epsilon, etc...which one is not converging?
Anyways, other thing to try: keep piso under relaxation - pressure = 0.4 under relaxation - momentum = 0.4 body force 1 turbulent knetic energy 0.4 turbulent dissip rate 0.4 for pressure-velocity coupling - presto first order upwind for others hope you are running unsteady model - check the model : 2D or 3D - steady or unsteady.. for unsteady : go to solve -> iterate variable time step and fix courant number to 0.5 min and max time steps can be like 1e-09 to 1e-03 ...i dont know your grid size so cant say much here. initialize - from inlet and iterate.. Let me know if it works...btw have you run Fluent VOF model before? Regargds, CFDtoy http://cfdtoy.blogspot.com Quote:
January 2, 2010, 11:41 |
#10 |
B. Selenbas
Rep Power: 16 |
hi,
the continuity was diverging. the others (k, epsilon ...) are almost constant (less than 1e-3). i meaned that while saying "(i'm not sure if i use steady, it gives true solution for only dispersion of water in air)", i said that, i already run unsteady, but if i use steady, in your opinion, does it be true for this problem, does the steady solution be true? i tried the parameters you wrote above, it runs at the moment, it doens't diverge. i had used vof model before, but the problem was easier than this, and mesh was quad. there was no problem with convergence. but here, there are tangential edges and the bad trihedral meshes on this surfaces, minimum mesh size is 3mm, tetrahedral cells. thanks Bugra |
January 2, 2010, 14:09 |
convergence
#11 | |
Continuity divergence is kinda expected ...your relaxation was too high and with the time step you use, the parameters i suggested above takes care of the variable update. Even with PISO if you use higher time steps, you may want to lower your relaxtion factors so that variable update remains under control. The simulation should run just fine now. Next time, when you get divergence..first place to see is solution controls, pressure momentum and turb settings ! /CFDtoy Visit http://cfdtoy.blogspot.com Quote:
eulerian model, mixture, multi phase, two phase, vof model |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Evaporatin water in the air | Morteza | FLUENT | 1 | August 20, 2008 06:04 |
VOF model of water film | Pathway | FLUENT | 1 | July 21, 2007 08:33 |
Multiphase model ...is it possible.. | Diana | FLUENT | 1 | November 11, 2002 14:24 |
Air and Water VOF model, Error?? | boris | FLUENT | 5 | July 19, 2002 04:08 |
