What's the causes of numerical oscillation?
Like Tree2Likes
  • 2 Post By shyamdsundar
Old   August 31, 2009, 07:33
Default What's the causes of numerical oscillation?
Edison
hadesmajesty is on a distinguished road
By taking the Fourier transformation, I find an oscillation in my solution with scaled wavenumber 3.14.
How such things can happen? I am using centered difference and RK method.
Thank you in advance.
hadesmajesty is offline   Reply With Quote
Old   September 3, 2009, 00:00
Shyam
shyamdsundar is on a distinguished road
I am not sure about the scaled wave number. Is it with respect to the cell width?
Anyway, I will try to provide a few points for cause of oscillations.
1)
In CFD, oscillations mostly occur at discontinuities. While solving, the numerical schemes try to fit the solution with a function, the degree of which would determine the order of the underlying scheme. Now, in the presence of discontinuities, a function approximation near the discontinuous solution would result in the so called Gibbs phenomenon. This becomes much more serious with higher order schemes.
2)
Oscillations can also occur due to the flux approximations. A less diffusive HLLC scheme would have more oscillations than the diffusive Lax Friedrich flux.
3)
Depending on the stability of numerical scheme, the (unstable) schemes could support certain modes of oscillations which can grow in time. A weakly unstable scheme can provide a better CFL limit, but would need some way of dissipating the unstable waves. For a central difference scheme, this would not be the case.
granzer and dengdeng like this.
shyamdsundar is offline   Reply With Quote
Old   May 7, 2012, 01:38
Default What about mesh size?
Himanshu Sharma
drhim86 is on a distinguished road
Hi to everybody,
I just want to know that does mesh size also play role in numerical oscillations? I have used tetrahedral mesh of size 7mm with size function attached to the airfoil which i have to study was of size 5mm which gradually increases merges with tetrahedral grid which as i have aforesaid was of size 7mm. I have applied unsteady DES and Standard k-omega model both are showing oscillations in converging solution. Thus i want to ask whether mesh size affects the oscillations in solutions.
drhim86 is offline   Reply With Quote
Summer School on Numerical Modelling and OpenFOAM hjasak OpenFOAM 5 October 12, 2008 14:14
Numerical dissipation/difusion in LES Ray FLUENT 2 June 10, 2002 06:15
numerical scheme ado Main CFD Forum 3 October 12, 2000 09:20
Standard for checking and testing numerical schemes? X. Ye Main CFD Forum 7 August 31, 1999 18:05
New Books and Numerical Software Eleuterio TORO Main CFD Forum 0 December 18, 1998 13:41
