How to calculate the first grid spacing (ds) using the NASA formula online?
Like Tree2Likes
  • 1 Post By Byron JI
  • 1 Post By ashish_singh
Old   May 21, 2009, 00:03
Default How to calculate the first grid spacing (ds) using the NASA formula online?
JI Bai-feng
Byron JI is on a distinguished road
hi ,everyone.
As all known, the Enhanced wall treatment needs that the y+ must be equal to 1 or below 5.
Some useful formula tools are aviable online, one is provided by NASA,as the following URL:
http://geolab.larc.nasa.gov/APPS/YPlus/
For a given Reynolds number, Mach number and desired y+ value, this page will estimate the spacing normal to a solid surface required to yield 1 grid point in the laminar sublayer.
Now , my problem is what is the Ref. Length meaning actually ?
R.Mah likes this.
Byron JI is offline   Reply With Quote
Old   May 21, 2009, 07:14
ashish
ashish_singh is on a distinguished road
Hi Byron,
Reference length is used to normalize length dimensions of geometry and also use to post process the data
It depends on the kind of problem you are dealing with. If it aircraft aerodynamics related problem, you must choose chord length of wing as a reference length. In automobile case people either use length of body or height of the body for reference length. Any way usually we need Y+ < 1 for aerospace kind of applications where viscous calculations are important.
It can be explained by a simple example too. If you have a cylinder of diameter D, then D will be your reference length to calculate ds for corresponding y+ value.
R.Mah likes this.
ashish_singh is offline   Reply With Quote
Old   May 21, 2009, 07:54
JI Bai-feng
Thanks a lot, ashish_singh
I think I got it.
Byron
Old   May 22, 2009, 01:40
Radiatn
radiatn is on a distinguished road
I tried that formula a few years ago and my result showed that the mesh layer size suggested by that formula is >5 times bigger than what should have been meshed. But that depends on the turbulence model you choose as well.
radiatn is offline   Reply With Quote
How to declare a symmetric tensor or calculate Huke formula haibinli OpenFOAM Running, Solving & CFD 0 July 28, 2006 11:24
Viscous Grid Spacing Calculator firedragon FLUENT 4 February 10, 2004 05:38
Grid Quality and the Solution Faraz Main CFD Forum 4 January 10, 2000 19:18
grid spacing question clifford bradford Main CFD Forum 5 November 10, 1999 19:40
Numerical methods for discontinuous grid interfaces? Hansong Hang Main CFD Forum 12 September 16, 1998 23:26
