PANAIR: PANEL METHOD CODE
Like Tree1Likes
  • 1 Post By fulkrum
Old   February 21, 2003, 06:37
Default PANAIR: PANEL METHOD CODE
Yogesh P
I would like to know if there exists any post-processor for "PANAIR (A502)" second order panel method based code. This code produces a very huge output file in ascii format. I am in process to develope the post processor and hence want to confirm if such post-processor exists or not. I have received this code from www.pdas.com which is version released in 1993. Can anybody help me in this reagard or provide more information? I would like to know if there are any users of this codes in INDIA.
Old   September 7, 2010, 20:25
Rauno
Location: San Diego (USA); Pisa (Italy); Munich(Germany)
fulkrum is on a distinguished road
Hi!
A little part of my master thesis consisted in writing a GUI postprocessor.
I did it in Matlab in order to expedit the process. Anyway, that is University of Pisa property (http://etd.adm.unipi.it/theses/avail...102009-175411/)
There are a couple of commercial tool too (Zonaair if I rememebr well), and other codes which were probably used times ago by the industries (Boeing...)
Just my 2 cents: the Post processor is quite easy and fast to implement, what it is really demanding is the the preprocessing.
Moreover, PanAir, as an higher panel method, don't admit any hole, and requires very sever abutment conditions.
And, it is not really efficient compared to a Low-order panel method.
I wouldn't recommend it, even if I used it a lot!
Ciao
golden1978 likes this.
fulkrum is offline   Reply With Quote
Old   February 1, 2014, 21:46
Hakan
golden1978 is on a distinguished road
Originally Posted by fulkrum View Post
Hi!
Ciao
Hi fulkrum!
I have sent you a private message. Please check it out and comback to me.
Thanks.
golden1978 is offline   Reply With Quote
Old   February 2, 2014, 06:41
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Hi!
That's impressive! How long did it take to develop the whole (pre and post processing) Matlab GUI?
lovecraft22 is offline   Reply With Quote
Old   February 2, 2014, 06:51
Rauno
Thank you :-)
If I remember well, the longest part of the work was devoted to the NURBS fair minimization algorithm and the structured mesh generator.
Pre and Post processor weren't the most difficult part, I can't remember exactly, but it probably took me 11/2-2 months (considering the fact that I had to learn PanAir and I had to learn how to program GUIs).
Old   February 2, 2014, 06:59
lore
11 months is not bad at all to program such a thing in Matlab! Congratulations!
Old   February 2, 2014, 15:19
Rauno
Eheh, actually I meant 1 and 1/2 - 2 months.:-)
Thank you anyway :-)
Old   February 2, 2014, 16:07
lore
Well, congratulations then! Don't know how deep the code goes behind the GUIs, but it looks like a lot of job anyway.
Is it robust in the end? And can the different GUIs interact/share data with each other?
Old   February 4, 2014, 04:25
Rauno
Thanks again.
After I was done with the work, I and the other guys used it. Obviously there were occasionally some minors bug, but overall the process was very straightforward: geometric design, meshing, call to solver (through the preprocessor) and results visualization (post-processor). Obviously, the different GUIs were interacting, so that the whole process was basically carried out in the same framework.
Old   October 26, 2015, 19:04
mehrdad_14
mehrdad_14 is on a distinguished road
hi , i want to know about panair , can you help me ?
i have some error
mehrdad_14 is offline   Reply With Quote
Sample SIMPLE method CFD code entitledx Main CFD Forum 8 May 27, 2012 07:22
Why use a panel method? gocarts Main CFD Forum 2 April 22, 2007 23:50
help 3D panel method luca Main CFD Forum 0 June 22, 2004 05:16
calculating missle configuration by panel method Daniel Main CFD Forum 5 January 6, 2003 09:09
seeking free 3D panel method code frederic felten Main CFD Forum 2 January 24, 2001 05:42
