False diffusion
Like Tree2Likes
  • 2 Post By drishty
Old   January 23, 1999, 19:36
Default False diffusion
Ehab
Hi I find a problem about the concept of False diffusion in CFD analysis. If any one know about this concept I will be appreciated. Thanks in Advance
Old   January 23, 1999, 21:05
Default Re: False diffusion
Luca Liberti
I am not too sure but I think you mean the numerical diffusion. If you try to solve a simple transport equation with numerical method such finite difference you will find that under some conditions related to the adimensional Courant number the transport term behaves like the diffusive term. You can see this effect by solving the simple monodimensional eqation of wave propagation with constant velocity c: df/dt=-c*df/dx if you use a simple forward differencing in time and backward in space (upwind) so that f(n+1)i=f(n)i-c*((f(n)i-f(n)i-1)/Dx)*Dt
you will find with that a simple triangular wave is translated but at the same time smoothed by a numerical diffusion effect that occours when the courant number Cr=dt*c/dx is less than 1 for grater values the scheme is unsteady for Cr=1 there is no diffusion. Bye
Old   January 25, 1999, 10:34
Jeff Franklin
I believe the area you are interested in is mostly call numerical diffusion. Many peopled have looked at these numerical problems and proposed solutions for them. The following article is a one of the many references in this area:
"Why you should not use 'Hybrid' 'Power-Law' or Related Exponential Schemes for Convective Modelling-There are Much Better Alternatives" Internationa Journal for Numerical Methods in fluids, Vol 20, 421-442 1995
Old   August 7, 2009, 13:43
Default false diffusion
drishty
drishty is on a distinguished road
False diffusion oftens arises when you are using an upwind differencing method to discretise equations. Though upwind differencing provides results closer to analytical ones, when the flow is not aligned with grid lines, this differencing method causes the transported properties to be smeared. the resulting error has a diffusion like appearance and is referred to as false diffusion.
If you need any further inormation pls ask
Drishtysingh
mahdi_kh8 and Teresa.Z like this.
drishty is offline   Reply With Quote
Old   August 7, 2013, 23:23
Talking
Mehdi
mahdi_kh8 is on a distinguished road
Send a message via Yahoo to mahdi_kh8
False diffusion is defined as an error having a diffusion-like appearance, obtained when the upwind scheme is used in multidimensional cases to solve for the distribution of transported properties flowing non-orthogonally to one or more of the system's major axes. The error is absent when the flow is orthogonal or parallel to each major axis.
mahdi_kh8 is offline   Reply With Quote
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
?? zero diffusion coefficient ?? ronen FLUENT 0 April 11, 2011 14:02
implementation of diffusion coefficients and use of diffusion coefficients stephan OpenFOAM Running, Solving & CFD 0 February 28, 2010 15:30
False Diffusion jj Main CFD Forum 2 September 29, 2006 01:44
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
