The Boundary Condition about the Flat Plate
Like Tree1Likes
  • 1 Post By frank
Old   January 4, 2002, 19:22
Default The Boundary Condition about the Flat Plate
boing
Hello, everone, I am trying to verifying my own code, I want to compute the laminar flow arond the flat plate , please give me some suggestions on the boundary treatment:
^ J
--> I
I = Imin : inflow boundary condition (Riemann Invar.) I = Imax : outflow boundary condition (Riemann Invar.) J = Jmin : (symmeteric boundary condition and non-slip
boundary condition) J = Jmax : farfield boundary condition
I used the boundary condition defined above, but I could not get the correct solution ?!
Old   January 6, 2002, 17:53
Default Re: The Boundary Condition about the Flat Plate
frank
Setting far field conditions at the upper boundary is wrong, if you set the v-velocity to zero. If you look at the blasius-solution you will immediately see, that the v-velocity does not approach zero but a constant value. So, you should treat the upper boundary (JMAX) as outflow. At IMAX using riemann invariants is not great either, since the entropy is not constant in the boundary layer. That might lead to big problems. I use a prescribed pressure and extrapolate the velocity and density. From that one can get the energy for the energy equation. The left border should be placed sufficiently away from the leading edge of the plate. I have a plate of length 2 and the left border about 0.5 or 1 from he leadin ede away.
rajibroy likes this.
Boundary layer over a flat plate using CFD hsnclk Main CFD Forum 5 April 30, 2020 10:34
Help: Fluid Flow Over a Horizontal Flat Plate by Boundary Layer Eq. egemen Main CFD Forum 0 May 20, 2011 05:57
turbulent boundary layer over a flat plate pritam.edke Main CFD Forum 0 November 5, 2009 13:53
Rotating interpolated boundary condition hani OpenFOAM Running, Solving & CFD 0 July 4, 2006 08:09
flat plate boundary layer data Ekachai Juntasaro Main CFD Forum 3 March 14, 2001 00:18
