Reynolds stress transformation
Like Tree2Likes
  • 1 Post By Deng
  • 1 Post By spy_hzdr
Old   October 23, 2001, 08:11
Default Reynolds stress transformation
P.Fonteijn
Hi all,
Is the answer on my question from several days ago too simple or does no one know how to do it??? Therefore, again my problem:
I have performed a simulation using a Reynolds stress model in cartesian coordinates. I know how to convert my x,y and z velocities to an x, r and phi-velocity (Bird, Stewart and Lightfoot). But how should I transform my Reynolds stresses to cylindrical coordinates????????? Does anyone know?
Any help or reference is appreciated. P.Fonteijn
Old   October 23, 2001, 11:46
Default Re: Reynolds stress transformation
Michael Malin
I believe there is an Imperial College report by Wolfgang Rodi around 1972 that gives the Reynolds stress equations in cylindrical-polar coordinates. I think they also appear in the Imperial College Phd Theses of Bassam Younis (early 1980s), Alan Morse (late 1970s) and possibly, Rodi (1972). They also appear in several UMIST theses (Brian Launder's research group)in the 1980s. If these references are too vague to follow up, let me know and I will try and dig out the exact references.
Old   October 24, 2001, 11:52
Deng
I am working on swirling flow computation. It is not easy to find Reynolds stress equation in cylindrical coordinates in the literature. When you find something, they are either incomplete or with typing errors. I put the transformed Navier-Stokes, k-epsilon and RSM equations in our ftp server (ftp://ftp.ec-nantes.fr/incoming/axis.ps). The Daly & Harlow model is used for the turbulent diffusion in the RSM model. Bye the way, concerning swirling flow computation with Reynolds stress model, with RANS computation, I am unable to confirme the result published in Phys, Fluids Vol.29 (1), pp 38-48 by Gibson & Younis for the free swirling jet (Morse test case). Result obtained with the SSG model is similar to the Gibson-Younis model and is not as good as presented in the paper by Younis, Gatski and Speziale (J. of Fluids Eng., Vol 118, 1996, pp 800-809). Any similar experiences or comments on turbulence modelling for swirling flow?
Old   October 24, 2001, 17:39
P.Fonteijn
Actually, I am not looking for Reynolds stress equation in the cylindrical coordinates as I don't want to perform simulations in cylindrical coordinates. I have already performed a cartesian solution providing u-,v-, w-velocities and:
u'u', v'v', w'w', u'v', u'w' and v'w'
I know how to transfrom the u-,v- and w-velocities to Vtangential (Vt) Vradial (Vr) and Vaxial (Va=u). How do I obtain:
Vt'Vt', Vr'Vr', Va'Vt', Va'Vr' and Vr'Vt?
To make a connection to your work, I have compared k-e-and a RSM in a swirling flow. Average velocities and periodic fluctuations were about the same. Main difference were the random fluctuations mentioned above which one could expect before hand (turbulent kinetic energy). The difference could be made visible using scalar mixing simulations.
I will dig up the references from you and Malin.
But, still every suggestion is highly appreciated.
Thank you all, P.Fonteijn
Old   October 25, 2001, 05:10
Deng
You can transforme the Reynolds stress in the same way. Since the instantaneous and the mean velocity follow the same transformation, you can obtain the similar relation for the fluctuation by substracting these two expressions, that is:
Vr'=V'cos(theta)+W'sin(theta) Vt'=-V'sin(theta)+W'cos(theta)
Multiply the two expressions and apply the mean operator to obtain:
Vr'Vt'=-V'V'cos(theta)sin(theta)+V'W'(cos(theta)**2-sine(theta)**2)+W'W'sin(theta)cos(theta)
Other stress components can be deduced in similar way.
He Junyi likes this.
Old   October 26, 2001, 17:38
P.Fonteijn
I think this is only possible when the Reynolds Stresses are vectors. I am not an expert but I thought they were scalars (I will check my literature). Could you comment on that?
Thanks, P.Fonteijn
Old   October 26, 2001, 18:23
ken
Reynolds stress are entries of "stress tensor". I suggest you check out some engineering statics/dynamics or continuum mechanincs textbooks. Some of the books can show you how to convert stress/strain from one coordinate system to the other. You can follow the same "procedures" to convert Reynolds stresses.
Old   September 11, 2017, 10:14
Pengyu SHI
spy_hzdr is on a distinguished road
Dear P.Fonteijn, I encountered with the same problem and still wonder if you have got the solution though it has been 16 years since your last post... Thanks.
spy_hzdr is offline   Reply With Quote
Old   September 12, 2017, 03:53
Pengyu SHI
If anyone encountered with this problem, see the link below which gives the solution:
http://www.brown.edu/Departments/Eng...lar_Coords.htm
sbaffini likes this.
Old   September 12, 2017, 05:03
sbaffini's Avatar
Paolo Lampitella
sbaffini will become famous soon enoughsbaffini will become famous soon enough
Send a message via Skype™ to sbaffini
However, as the Reynolds Stress Tensor is just made up of velocity products, the answer by deng is also correct. You just need to transform velocity components and to multiply them. Sometimes this is more straightforward than remembering the transformation rule for tensors.
sbaffini is offline   Reply With Quote
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 01:01
Reynolds Stress Models Jade M Main CFD Forum 0 April 21, 2010 17:38
Reynolds Stress Boundary Conditions tstorm FLUENT 0 July 27, 2009 15:44
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 08:37
reynolds stress tufito Main CFD Forum 3 March 10, 2005 16:40
