What's the numerical boundary layer
Like Tree1Likes
  • 1 Post By Jim Park
Old   May 29, 2001, 04:23
Default What's the numerical boundary layer
Zhou
What's the definition of 'numerical boundary layer' and what's the physical mean of it? Thank you!!!
Old   May 29, 2001, 06:56
Default Re: What's the numerical boundary layer
John C. Chien
(1). numerical boundary layer is likely = numerical analysis of boundary layer flows, or = numerical boundary layer analysis. (2). So, numerical = numerical analysis.
Old   May 29, 2001, 08:07
Leo
it's wrong
Old   May 29, 2001, 10:52
Jim Park
One answer (perhaps not the only one) has to do with the error generated by poor numerical resolution of a boundary region.
Generally, the physical boundary layer thickness (flat plate theory) for a laminar flow is scaled by
delta / x = (nu / (x * U))^(0.5),
where delta is the boundary layer thickness, x is the distance from the leading edge of the plate, nu is the kinematic viscosity of the fluid, and U is the free stream velocity of the flow.
Of course, U * x / nu = Re, the Reynolds number for the flow.
These results above are not from CFD but from classical Fluid Mechanics. More info can be obtained from the texts by Schlichting (Boundary Layer Theory) or any of several modern books on convective heat transfer.
Now to CFD:
If the advection (or convection) terms in the NS equations are differenced using upwinding, an analysis of the numerical error due to the difference approximations will often show an error term of the form
ExtraVis = C| Rec |(Ur - Uc)
C is a constant based on upwinding parameters (zero for central differencing), Ur and Uc are the upstream and centered discrete velocities at the centers of computational cells, and
dx is the width of the computational cell parallel (not normal) to the solid boundary.
Rec is the "Cell Reynolds Number", U * dx / nu .
This analysis technique is detailed by C. W. Hirt, "Heuristic Stability Theory for Finite-Difference Equations," J. Comp. Physics, v. 8, p. 119 (1968).
The point is that ExtraVis, above, adds to the natural viscosity of the fluid in the difference equations due to the upwinding, generating a numerical viscosity. This can have the effect of artificially increasing the thickness of the COMPUTED boundary layer.
delnum / x = (nu*(1 + ExtraVis) / (x * U))^(0.5)
where delnum is the thickness of the numerical boundary layer.
The details of this analysis of course depend very much on the details of the differencing employed; this is just another demonstration that inadequate spatial resolution leads to errors in the computed flow.
samina likes this.
Old   May 29, 2001, 13:20
Han
I have heard the term numerical boundary layer before and its use differed from that explained in the previous post.
A boundary condition applied in a CFD calculation is not generally an exact physical boundary condition,it is some approximation. The distance from this boundary condition until the point at which the solution can be trusted is called the numerical boundary layer.
Han
Old   May 29, 2001, 15:28
Adrin Gharakhani
In which context did you see the term "numerical boundary layer"?
Adrin Gharakhani
Old   May 29, 2001, 20:05
John C. Chien
(1). I think, it is just something interesting.
Old   May 29, 2001, 23:48
Zhou
Thank you, Adrin. I notice the term in the book 'Incompressible computational fluid dynamics' (G.E. Karniadakis, Orszag, Ronquist and Patera). This term appears in the context of estimation of error. I consider the above answer by Leo may be correct.
Old   May 30, 2001, 01:59
John C. Chien
(1). The person who invented it is responsible for it. So, if he is still alive, why not e-mail him to get his direct comment. (2). Apprently, he is from FEM world.
Old   May 30, 2001, 15:13
Adrin Gharakhani
I have used the term "numerical boundary layer" in my publications to denote a wall boundary layer model that mimimcs the physical phenomenon but as far as the characteristic length scales are concerned the numerical model is not exactly the same as in the physical world. So, this is a "numerical" and not "physical" boundary layer, since it solves the same physical boundary layer equations, but at a different length scale - say for thinner layers than physics would dictate.
Adrin Gharakhani
Old   May 30, 2001, 18:35
  #11
John C. Chien
(1). Perhaps "wall layer", "modelled wall layer", or "pseudo wall layer" would be better than "numerical boundary layer". (2). The other way to do is to use "numerically induced boundary layer".
Old   June 1, 2001, 19:27
  #12
clifford bradford
Unfortunately I have seen the term used in other contexts so it really is a sort of misused term that shouldn't be taken to have a general meaning ie it should be explicitly explained whenever it's used.
Old   June 2, 2001, 00:17
  #13
Adrin Gharakhani
Agree. Strictly (or even loosely) speaking "numerical boundary layer" doesn't mean anything. And indeed, I usually put mine in quotes and explain (or refer to a publication that does) what I mean by the term.
Adrin Gharakhani
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Turbulent Boundary Layer on a Flat Plate Hoshang Garda FLUENT 1 November 27, 2013 11:24
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
Please help with flow around car modelling! Tudor Miron CFX 17 March 19, 2004 20:23
Wall turbulence, viscosity, boundary layer Patrick Godon Main CFD Forum 1 November 5, 2003 16:39
