Detached Eddy Simulation
Like Tree1Likes
  • 1 Post By Jim Forsythe
Old   November 21, 2000, 11:03
Default Detached Eddy Simulation
Fred
I am currently working on the simulation of the turbulent flow around a helicopter fuselage. I still have to weigh different options wrt. the turbulence models. Since the flow is separated at many locations, I don't think conventional LES (either with Smagorinsky or dynamic SGS) will work properly. Is there anybody who knows some good references about DES? It seems to be the way to go for separated flows. Respectfully.
Old   November 21, 2000, 13:18
Default Re: Detached Eddy Simulation
frederic felten
Hi there,
Check the following paper: "Approach to wall modeling in large-eddy simulations." Nikitin, N.V.; Nicoud, F.; Wasistho, B.; Squires,K.D.; Spalart, P.R. Physics of Fluids, v12, n7, 2000, pp 1629-1632.
Abstract: In this study, the detached-eddy simulation (DES) model was applied without adjustment as a subgrid-scale (SGS) model in the large-eddy simulation (LES) of channel flow. Following this, simulations were conducted on personal computers and work stations. Overall, the results are stable and fairly accurate.
I hope this helps. Sincerely,
Frederic Felten CFD Laboratory, UT Arlington. http://utacfdb.uta.edu/~felten
Old   November 21, 2000, 19:16
Jim Forsythe
I'd love to see you try DES. I'm currently working on spinning an aircraft using DES along with Kyle Squires (http://www.eas.asu.edu/~squires/) and Phillipe Spalart using Cobalt60 (http://www.va.afrl.af.mil/vaa/vaac/cobalt/Co_main.html). You can check out some of our work (a very shoddy web page) at: http://www.usafa.af.mil/dfan/des.htm. My dissertaion was putting DES into Cobalt60 (an AF developed unstructured solver) and running it on a supersonic base flow. You can get a pdf of it, and the AIAA paper at: http://www.usafa.af.mil/dfan/forsythe.htm. It will provide the original DES references. Kyle's web page has some stuff on flow over a sphere as well.
If you are a US citizen you may want to consider running Cobalt - it has been run succesfully on a few helicopters (not using DES though). If you are interested, I can get you started with it. It is unstructured, so grid generation is relatively easy.
Please feel free to drop me an e-mail. I think DES will do no worse than RANS, and perhaps quite a bit better.
Jim Forsythe USAF Academy
Aviatamin likes this.
Old   November 22, 2000, 07:28
andy
As means to promote discussion, can someone tell me how the DES approach differs from where LES started? - when approximate wall treatments were used because one could not resolve the boundary layer? Excluding obvious academic marketing potential does it justify yet another label?
Old   December 16, 2000, 10:45
Raj Bissessur
I'm looking to gather all relevant articles relating to hybrid RANS/LES (DES) methods whic have been applied to unsteady flows.
Thanks
domain size for Detached Eddy Simulation T FLUENT 0 November 6, 2007 13:23
Detached Eddy Simulation in industry Fab Main CFD Forum 3 January 18, 2007 15:50
Large eddy simulation David FLUENT 1 December 11, 2006 13:18
Detached Eddy Simulation Juan Guevara CFX 3 December 21, 2005 15:47
Large Eddy simulation Andreas Hauser Main CFD Forum 1 May 20, 2000 21:33
