SnappyHexMesh directional refinement
Like Tree1Likes
  • 1 Post By bruce21
Old   November 22, 2024, 06:30
Default SnappyHexMesh directional refinement
Sudharsan Bharatwaj
bruce21 is on a distinguished road
Hi CFD community,
I am using snappyHexMesh to refine my axisymmetric mesh (which uses a wedge boundary condition). I created this wedge domain using Gmsh. When I try refining the mesh, I see that the wedge boundaries lose their planarity. I see this is because snappy is refining the mesh in Y axis (around the axis of symmetry) also. Please see the attached dictionary file.
I need to refine the mesh only in X and Z direction, but not Y. I realized that refineMesh can do this, but the resulting mesh isn't satisfactory.
So, is there a way to specify directionality (refine only in specified axis) while using snappyHex for refinement?
Thanks in advance!
bruce21 is offline   Reply With Quote
Old   November 22, 2024, 07:33
Lucky
Not in snappy, no. Snappy is not a mesher, it is a tool that makes a mesh snappy. Snappy is also not a tool for refining a mesh.
Is your domain a simple wedge? If so, return to the original blockMesh, you don't need snappy. If you have a wedge with a car inside it then:
Two other ideas you may like to try
1) Increase the resolution in the X and Z direction in the original blockMesh. Then snap it.
2) Scale the mesh in the Y direction smaller. Run snappy. Then scale the Y-dimension back up.
Old   November 22, 2024, 09:03
M
AtoHM is on a distinguished road
The ESI version of snappyHexMesh does support directional refinement.
AtoHM is offline   Reply With Quote
Old   November 24, 2024, 14:33
Sudharsan Bharatwaj
Hi LukcyTran,
I don't have an object for thr mesh to snap on. But, I created the mesh using GmsH and it's kind of a hard deal to do add refinement regions by manually creating blocks (which you probably already know). That is why I wanted to use a refinement utility within openfoam.
However, thanks for the suggestions. I will go back to using a blockMesh and try out these methods if I couldn't find a (easier) solution soon.
Old   November 24, 2024, 14:37
Sudharsan Bharatwaj
Hi AtoHM,
Thanks for the reply! That's good news . If possible, can you share a sample snappyHex dict file with the directional refinement classes in it? I'll try installing the ESI version and give it a try.
Old   November 25, 2024, 06:33
Yann
Yann will become famous soon enoughYann will become famous soon enough
Here are the release notes when directional refinement has been introduced in OpenFOAM-v1806:
https://www.openfoam.com/news/main-n...pre-processing
A stretching feature also appeared in the next release (OpenFOAM-v1812):
Any version from ESI released after v1812 should have these features.
Yann is offline   Reply With Quote
Old   November 25, 2024, 08:11
Lightbulb
Sudharsan Bharatwaj
Originally Posted by Yann View Post
Here is the release notes when directional refinement has been introduced in OpenFOAM-v1806:
Hi Yann,
That is superb! Thank you so much for the link. On first glance, it looks like that is exactly what I was looking for.
Yann likes this.
axisymmetric, openfoam, snappyhexmesh, wedge mesh axisymmetric
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
