June 18, 2024, 06:59 |
3D mesh generating using snappyHexMesh
Rep Power: 2 |
Dear foamers,
I was trying to generate a mesh using snappyHexMesh and this is what I currently have: nozzle2Dcase2.png As you can see, this quite a bad mesh and I would like something more like this: nozzle2Dcase3-1.jpg Any ideas about which command and how can I obtain a more structured mesh and potentially composed by hexahedrons solely? Thank you |
June 18, 2024, 08:25 |
Rep Power: 8 |
with snappyhexmesh you can not generate purely hex mesh, because in the snapping stage hex cells will be split.
you can refine the surface though and add layers which will look much better. PS: it is a better idea to post openfoam related things in the openfoam sub-forum |
June 18, 2024, 10:22 |
Lucky
Rep Power: 66 |
You cannot do a body-fitted grid with snappyHexMesh, that invalidates the "snappy" part of snappyHexMesh.
You need an external tool. ICEM, GridPro, etc. OpenFOAM does not provide tools that does such a grid. |
June 18, 2024, 10:40 |
Rep Power: 16 |
You can do much with blockMesh, for example:
https://curiosityfluids.com/2019/04/...sh-an-example/ Gmsh is a good option for structured axisymmetric nozzles. Edit: not sure why I read ”nozzle” |
snapphhexmesh, snappyhesmeshdict, snappyhexmesh 3d |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] non uniform mesh near the stl object | vava10 | OpenFOAM Meshing & Mesh Conversion | 0 | January 31, 2021 14:41 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
