heat transfer rate is not increasing with thermal diffusivity |
April 20, 2024, 23:30 |
Md. Mesbahose Salekeen
Rep Power: 8 |
I am trying to solve 1D convection diffusion equation using finite difference (Crank Nicholson Method):
0.0002 to 0.001 incrementing by 0.0001 The question is to find the time it requires and compare that time with alpha values. For the x-direction, central difference and for time derivative, forward difference was used. For the right boundary, backward difference is used. I tried my code in python: Code:
import numpy as np import matplotlib.pyplot as plt j = 7 u = 0.002*(1+j) L = 2 ndx = 1001 dx = L/(ndx-1) alpha = np.arange(0.0002, 0.001+0.0001, 0.0001) dt = min(dx**2/(2*min(alpha))*.8, 0.8*dx/u) ndt = int(320/dt)+1 x = np.linspace(0, 2, ndx) Temperature_of_node_to_check = int(1.5/dx) t_1_5 = np.zeros(alpha.size) courant_number = u*dt/dx if courant_number < 1: print("C < 1" + "ok") peclet_number = u*L/alpha if any(peclet_number <= 2): print("P <= 2" + "ok") cell_peclet_number = u*dx/(2*alpha) if any(cell_peclet_number < 2): print("C.P < 2" + "ok") s = alpha*dt/dx**2 if any(s <= 0.5): print("s <= 0.5" + "ok") courant_number = (u*dt/dx)*np.ones(alpha.size) diffusivity = alpha*dt/dx**2 a = -(courant_number/2.0+diffusivity) b = 2*(1+diffusivity) c = (courant_number/2.0-diffusivity) T = np.zeros(shape=(ndt, ndx)) T[0,:] = 10+j T[:,0] = 30 D = np.zeros(ndx-2)*1.0 def thomas(a, b, c, D): N = D.size C = np.ones(N-1)*c B = np.ones(N)*b A = np.ones(N-1)*a A[N-2] = a-c/3.0 B[N-1] = b + (4/3.)*c C[0] = C[0]/B[0] D[0] = D[0]/B[0] for i in range(1, N-1): C[i] = C[i]/(B[i-1]-A[i-1]*C[i-1]) D[i] = (D[i]-A[i-1]*D[i-1])/(B[i]-A[i-1]*C[i-1]) D[N-1] = (D[N-1]-A[N-2]*D[N-2])/(B[N-1]-A[N-2]*C[N-2]) result = np.zeros(N) result[N-1] = D[N-1] for i in range(N-2, -1, -1): result[i] = D[i] - C[i]*result[i+1] return result k = 0 for ai, bi, ci, alphai, coi, diff in zip(a,b,c,alpha, courant_number, diffusivity): for i in range(ndt-1): for j in range(1, ndx-1): D[j-1] = (coi/2.0+diff)*T[i,j-1] + 2*(1-diff)*T[i,j] + (-coi/2+diff)*T[i,j+1] D[0] = D[0] - ai*T[i,0] T[i+1,1:ndx-1] = thomas(ai,bi,ci,D) T[i+1,ndx-1] = (4/3.)*T[i,ndx-2] - (1/3.)*T[i,ndx-1] if T[i+1, Temperature_of_node_to_check] >= 25.: t_1_5[k] = (i+1)*dt print((i+1)*dt) break fig, ax = plt.subplots(1, 1, figsize = (24,24)) label = r'$\alpha$' + '={:.5f} '.format(alphai) + r'$m^{2}/s$' + r' t = {:5f}'.format((i+1)*dt) ax.plot(x, T[i+1,:], "--g", label = label) ax.set_xlabel("x", fontsize = 30) ax.set_ylabel("T", fontsize = 30) ax.legend(fontsize = 30) plt.plot(x, T[i+1,:], "--g") plt.yticks(np.linspace(16,32, 9)) plt.plot([0,1.5],[25,25],'k') plt.plot([1.5,1.5],[25,17],"k") filename = "alpha={:.5f}".format(alphai) + ".jpg" plt.savefig(filename) k = k + 1 plt.close() plt.plot(alpha, t_1_5, "--r") title = "Time Taken to rech " + r"$25^{o} C$" + " vs " + "diffusivity" plt.title(title, fontsize = 10) plt.xlabel(r"$\alpha$", fontsize = 20) plt.ylabel(r"$T_{1.5}$", fontsize = 20) plt.yticks(fontsize = 10) plt.xticks(fontsize = 10) Here the graph generated from t vs [math]\alpha[math]. As the thermal diffusivity increases from 0.0002 to 0.001, heat transfer decreases as it requires more time. After 0.002, the heat transfer rate increases which is what I was expecting. What happens in lower values of alpha that heat transfer decreases? Is it due some numerical error or some other reason? Last edited by Alvin1990; April 22, 2024 at 01:12. Reason: coupling dt with dx so that alpha*dt/dx^2 <= 0.5 |
April 20, 2024, 23:35 |
Rep Power: 8 |
the images are uploaded in google drive
https://drive.google.com/file/d/1OMU...usp=drive_link https://drive.google.com/file/d/1KYV...usp=drive_link |
April 20, 2024, 23:47 |
Lucky
Rep Power: 66 |
Central differencing is not appropriate for the advective term and is terribly inaccurate when the Peclet number is not less than 2.
You can repeat your calculations at different grid sizes and immediately see the impact. And since Pe<2 are diffusion dominated problems, this is why people don't use central differencing for the advective term for convection problems. To be clear, central differencing the diffusion term is 100% okay. |
April 21, 2024, 00:14 |
#4 | |
Rep Power: 8 |
Thanks you for the comment. If I reduce the grid size there is a significant difference. Will upwind scheme circumvent the issue? |
April 21, 2024, 01:09 |
Lucky
Rep Power: 66 |
The alternative is, you stick with central differencing but using a super dense grid to drive down the Peclet number.
A pure (1st order) upwind scheme has the same issue but the other way. Upwind isn't great for Pe<2. However, since it's very easy to create a coarser grid and jack up the Peclet number, it's favorable and is more optimal. I mention this scheme mostly for educational purposes. A 2nd order upwind scheme or Crank-Nicolson scheme is straightforward to code and works for most problems but the error analysis doesn't give a simple clear rule like Pe>2 versus Pe<2 |
April 21, 2024, 03:30 |
Filippo Maria Denaro
Rep Power: 73 |
What you are using is the so called FTCS scheme. It works accurately provided that the cell Peclet number is <2 as previously stated.
Furthermore the stability constraint for such a low cell Peclet value requires a small time step. I strongly suggest to check first your code using the analytical solution for the steady case with Dirichlet conditions. Then, if it works correctly, check the solution with Neumann BC. |
April 22, 2024, 01:49 |
Rep Power: 8 |
I edited my code to take account of dx and dt, so courant number < 1 and alpha*dt/dx^2 <= 0.5. The cell peclet number stays less than < 2. As for higher values of alpha the results start to diverge. What other methods can be used to get consistent and correct result? I have used implicit method(unconditionally stable) to solve it but difficulty understanding whether this method provides accurate result or not?
April 22, 2024, 03:01 |
#8 | |
Rep Power: 73 |
April 22, 2024, 03:22 |
#9 |
Rep Power: 8 |
There is no heat flux on the left end. It will have constant 30 deg temperature. Right side is insulated. Maximum temperature possible is 30 deg celcius.
April 22, 2024, 03:29 |
#10 |
Rep Power: 73 |
You are not award that while prescribing the temperature you will get a heat flux? Compute it during the computation.
April 22, 2024, 04:08 |
#11 |
Rep Power: 8 |
There will be heat flux as node 1 temperature is 30 deg and node 2 temperature 17 deg. But this difference/heat flux should go down due to advection and diffusion and when all nodes will reach 30 deg, heat transfer will stop.
April 22, 2024, 05:26 |
#12 |
Rep Power: 73 |
The steady state is the constant but you need to be sure the the transient has no oscillations. As I wrote, check first the analytical solution.
crank nicolson, finite difference method, thermal diffusivity |
Help needed: Simple pipeline flow heat exchange, yet the total heat transfer rate re | RC_Jiang | FLUENT | 0 | March 25, 2024 20:49 |
how to set up a two way FSI with heat transfer? | Shuo_Yuan | FLUENT | 1 | June 25, 2023 03:12 |
Flow around heatsink with heat transfer | S Mughal | FLUENT | 0 | April 13, 2018 13:06 |
Simple piston movement in cylinder- fluid models | arun1994 | CFX | 4 | July 8, 2016 02:54 |
how can I get the net heat transfer rate in every time step? | hotboy | FLUENT | 0 | October 22, 2015 07:52 |
