Which turbulence model is suitable for structured surface pool boiling simulation |
January 22, 2024, 09:00 |
marcus aurelius
Rep Power: 3 |
This is a generalized question related to CFD.
I am trying to simulate Pool Boiling simulation over structured surface having micro-grooves using RPI wall boiling model. I did the minimum cell size calculation with Y+ equation (assuming Y+=30) and found out that the cell size should be around 3 mm. However, the structured surface has micro-grooves of 0.5 mm. This means mesh will go much below the recommended value of 3 mm. In that case, what will be the best approach to select Turbulence model? |
January 22, 2024, 16:02 |
#2 | |
ONESP-RO
Rep Power: 5 |
▶ To read some review papers about turbulence models applied in similar cases to yours. ▶ Or, Conduct your own numerical test and compares with experimental results. Regards
Don't keep making the same mistakes. Try to make new mistakes. |
January 22, 2024, 16:12 |
#3 | |
Arjun
Rep Power: 34 |
Then the mesh sizes go much below 3mm and yplus will be much lower than say 1. It hardly matters, if the solver offers low re formulation for wall then use that or just use all re (or all yplus) formulation and solver shall take care of walls. You do not have to have yplus of 30 or any fixed number as long as its not too high. (it all depends on case in question). |
ansys, multiphase, rpi wall boiling, turbulence modeling |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Which turbulence model is applicable for Plain diffuser flow simulation in openFOAM? | mukut | OpenFOAM Running, Solving & CFD | 4 | January 30, 2015 09:06 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
HELP!: swimming pool flow problem | Tee | FLUENT | 1 | September 8, 2005 09:29 |
Turbulence model in flow driven by surface tension | Z. ZENG | Main CFD Forum | 7 | April 28, 1999 08:18 |
